查看: 2988|回复: 15
大家帮着看看这个镜头
发表于 2004-9-13 19:49:00 | 显示全部楼层 |阅读模式
<img src="data/attachment/forum/dvbbs/2004-9/2004913114929193.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'data/attachment/forum/dvbbs/2004-9/2004913114929193.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
大家帮着看看这个镜头
大家帮着看看这个镜头
大家帮着看看这个镜头
大家帮着看看这个镜头
大家帮着看看这个镜头
大家帮着看看这个镜头
 楼主| 发表于 2004-9-13 19:50:00 | 显示全部楼层
<img src="data/attachment/forum/dvbbs/2004-9/2004913115020905.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'data/attachment/forum/dvbbs/2004-9/2004913115020905.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
<img src="data/attachment/forum/dvbbs/2004-9/2004913115055692.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'data/attachment/forum/dvbbs/2004-9/2004913115055692.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
 楼主| 发表于 2004-9-13 19:51:00 | 显示全部楼层
<img src="data/attachment/forum/dvbbs/2004-9/2004913115147809.jpg" border="0" onload="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onmouseover="if(this.width>screen.width*0.7) {this.resized=true; this.width=screen.width*0.7; this.style.cursor=\'hand\'; this.alt=\'Click here to open new window\nCTRL+Mouse wheel to zoom in/out\';}" onclick="if(!this.resized) {return true;} else {window.open(\'data/attachment/forum/dvbbs/2004-9/2004913115147809.jpg\');}" onmousewheel="return imgzoom(this);" alt="" />
 楼主| 发表于 2004-9-13 19:58:00 | 显示全部楼层
<P>自己感觉这个透镜优化出来怪怪的,第一片是成了负透镜,</P><P>焦距5.42mm,  F#=6.5</P>
发表于 2004-9-13 20:39:00 | 显示全部楼层
楼主是直接用MTF优化的吧,权值设的太高会出现这样的问题。
 楼主| 发表于 2004-9-13 21:13:00 | 显示全部楼层
的确是用MTF直接优化的,这个结构加工出来有问题吗?
发表于 2004-9-13 21:39:00 | 显示全部楼层
这样的结果加工出来后边缘视场会不好,弥散斑太大。
 楼主| 发表于 2004-9-13 23:05:00 | 显示全部楼层
我的想法是:像质完全可以用MTF来反映(除了畸变和照度),
既然边缘视场的MTF值不低,像质应该能够接受。
不知道对否。
发表于 2004-9-13 23:23:00 | 显示全部楼层
如果公差没有问题,那就没有问题.MTF还是比较准的.但是对有特殊要求的就不一定适用了.如SPOT.
发表于 2004-9-14 01:21:00 | 显示全部楼层
这个系统的相对孔径不大
点列图的效果不好
发表于 2004-9-14 04:40:00 | 显示全部楼层
弥散班偏大,传函结果有问题
