查看: 7997|回复: 12
ASAP入门实例剖析之一
发表于 2013-7-13 09:37:08 | 显示全部楼层 |阅读模式
SYSTEM NEW
RESET
!! Setup optical property data base
UNITS MILLIMETERS          !! Set system units
WAVELENGTHS 0.4861 0.5876 0.6563 UM  !! Microns to mm conversion
MEDIA
  1.7  1.6  1.5   'GLASS'  !! Define refractive indices
COATING PROPERTIES
  0 1  0 1  0 1   'TRANS'  !! Define coating properties "r t"
!! Setup entity data base
SURFACE                    !! Key word for entity data base entry
  PLANE Z 0 ELLIPSE 10     !! Entity surface type
OBJECT 'BACK_SIDE'         !! Setup object data base
  INTERFACE COATING TRANS AIR GLASS  !! Assign optical properties to object
SURFACE
  OPTICAL Z -5 20 ELLIPSE 10
OBJECT 'FRONT_SIDE'
SURFACE
  PLANE Z 29.8 ELLIPSE 5
OBJECT 'DETECTOR'  !! With no INTERFACE command it defaults to totally absorbing
!! Setup sources
BEAMS INCOHERENT GEOMETRIC      !! Assign physical property to source
WAVELENGTH 0.5876 UM
GRID POLAR Z -5 0 5 0 360 10 6     !! Define spatial property & flux
  SOURCE DIRECTION 0 SIN[5] COS[5] !! Define angular property
  MOVE TO Z -10                    !! Force rays to start at this point
!! Perform simple analysis
TITLE 'SIMPLE LENS ANALYSIS'    !! Set title for future plots
PRINT                           !! Verify system numerically
WINDOW Y Z
  PROFILES 'SYSTEM GEOMETRY'    !! Verify system graphically
STATS POSITION                  !! Verify ray data numerically
STATS DIRECTION
WINDOW Y X
  SPOTS POSITION ATTRIBUTE 1 'INPUT' !! Verify ray data graphically
WINDOW Y Z
  PLOT FACETS 4 4               !! Draw picture of system
  PROFILES OVERLAY              !! Draw a profile slice through system, with ray trace
  TRACE PLOT
$VIEW                           !! View geometry and ray trace in 3-D viewer
CONSIDER ONLY DETECTOR          !! Isolate ray data on OBJECT
  FOCUS MOVE                    !! Move ray data to best focus
WINDOW Y X
WINDOW 1.2                      !! Enlarge current window by 20%
PIXELS 101                      !! Set higher resolution (default=39)
SPOTS POSITION 'SPOT DIAGRAM'   !! Plot spot diagram and create data distribution file
DISPLAY                         !! Load spots file into display
  ISOMETRIC 'ISO PLOT OF SPOTS DIAGRAM' !! Some different display commands
  PLOT 'PLOT3D OF SPOTS DIAGRAM
  CONTOUR 'CONTOUR PLOT'
RETURN
该贴已经同步到 asdoptics的微博
发表于 2013-9-27 14:39:18 | 显示全部楼层
高手
 楼主| 发表于 2013-9-27 15:04:26 | 显示全部楼层
sowind 发表于 2013-9-27 14:39
高手
 楼主| 发表于 2013-9-30 15:35:12 | 显示全部楼层
发表于 2013-10-7 22:35:42 | 显示全部楼层
謝謝分享~~~
发表于 2013-10-9 14:33:11 | 显示全部楼层
发表于 2013-10-12 16:24:37 | 显示全部楼层
发表于 2013-10-14 14:11:01 | 显示全部楼层
发表于 2013-10-14 14:11:12 | 显示全部楼层
发表于 2013-10-16 15:39:34 | 显示全部楼层
发表于 2013-10-16 15:42:04 | 显示全部楼层
发表于 2013-10-30 09:21:48 | 显示全部楼层
多多交流哦
