查看: 2735|回复: 2
[产品] CIOE2013:Cube Optics AG携新品参加光博会
发表于 2013-8-22 08:49:39 | 显示全部楼层 |阅读模式
ACTIVE-Cubes: Multi-Lambda ROSAs
CUBO provides multi-lambda ROSAs (Receiver Optical Sub-Assemblies) for integration in high-speed transceivers. Our ROSAs are available for 40G and 100G transceivers according to the IEEE 802.3ba Ethernet Task Force (baseline) standards. The 40G ROSA demuxes 4 CWDM channels at 10Gbps, the 100G ROSA demuxes 4 LAN WDM channels at 25Gbps.
- 40Gbps and 100Gbps
- Integrated Optical Mux/Demux with PDs, TIAs, Lasers & Drivers
- IEEE 8002.3ba compliant
CWDM COLOR-Cubes - 40 & 100GBase-LR4 CWDM & LAN-WDM
Coarse Wavelength Division Multiplexing (CWDM) is an excellent choice for increasing bandwidth capacity while keeping costs down. The COLOR-Cube family, based on standard Thin Film Filter (TFF) technology with a proprietary packaging, offers you smallest component dimensions combined with an outstanding performance and reliability.
- Reduced-Size Multiplexers for CFP Transceivers
- Telcordia, RoHS proven
Cube Optics AG
展位号: 1A09-3
www.cubeoptics.com
info@cubeoptics.com
Cube Optics is a leading provider for passive and active fiber-optical components, modules, systems and turn-key fiber-optical transport solutions. Our component portfolio covers all types of passive components like fused couplers, PLC splitters, fiber-optic switches, connectors and adapters with focus on optical wavelengths division multiplexers, from Wideband (WWDM), over Coarse (CWDM) and Dense (DWDM) to LAN WDM and proprietary, customized grids. Those are completed by active counterparts, (de-)multiplexers with integrated active elements like lasers or detectors forming multi-lambda Receiver and Transmitter Optical Sub-Assemblies (ROSAs / TOSAs).
Our vertical integration is also providing carrier-grade, simple and low-cost fiber-optic transport solutions based on our own components. Our offer ranges from pluggable transceivers (GBIC, SFP, XFP, SFP+, X2, CFP etc), passive as well as active transport systems to providing consultancy on network design, installation and services.
发表于 2013-8-22 13:00:18 | 显示全部楼层
支持
 楼主| 发表于 2013-8-23 08:49:50 | 显示全部楼层
Chris-ASD 发表于 2013-8-22 13:00
支持
谢谢支持!
