The ASAP script language creates surfaces that are optimized for ray tracing. This is a key difference between ASAP and other optical software packages powered by solid-modeling engines or coupled directly to CAD programs. These packages often produce geometry elements that are not optimized for ray-tracing engines. Investing the time to model key geometry components within ASAP also makes the full functionality of the ASAP script language accessible, including the ability to automate analyses of multiple design iterations using system parameterization.
