查看: 2160|回复: 1
[产品] it can keep the temperature what you want
发表于 2014-2-18 16:15:43 | 显示全部楼层 |阅读模式
Are you a fans of science and technology?If you want something to keep the temperature you want ,see it.
ATTP1A is a Temperature Plate Assembly, designed for evaluating TEC controllers in an easy way. This TEC assembly is widely used for evaluating TEC controllers, TECs and heat sink, etc. Also it can stabilize objects temperature for scientific experiments. This temperature plate ATTP1A provides a platform with wide temperature regulation range: -20°Cto 110°C.
To meet customers' requirements, we design and make customized products, in addition to the standard off-the-shelf ones. Contact us if make special products for you.
Are you interested in it?More information please see www. analogtechnologies.com
 楼主| 发表于 2014-2-18 16:17:26 | 显示全部楼层
