查看: 87860|回复: 8
[原创] 《Matlab辅助激光光学分析与应用》(2014年 第三版)发布
发表于 2014-5-30 22:53:44 | 显示全部楼层 |阅读模式
购买链接:http://item.taobao.com/item.htm? ... &id=39287869670
目 录
MATLAB辅助激光光学分析与应用....................................................................................................I
MATLAB辅助激光光学分析与应用...................................................................................................II
作 者:刘良清..............................................................................................................................II
第一章 光的波动性和衍射............................................................................................................... 1
1.1 MAXWELL方程组和电磁波........................................................................................................1
1.2 波动方程.......................................................................................................................................4
1.3 衍射...............................................................................................................................................5
1.3.1 小孔衍射................................................................................................................................6
1.3.2 双缝衍射..............................................................................................................................14
1.4 波前畸变.....................................................................................................................................17
1.4.1 Zernike多项式......................................................................................................................17
1.4.2 畸变光束的衍射..................................................................................................................20
1.5 光束通过光学元件的变换.........................................................................................................24
1.5.1 平行光束通过透镜的聚焦..................................................................................................24
1.5.2 高斯光束通过透镜的聚焦..................................................................................................30
1.5.3 自聚焦透镜..........................................................................................................................32
1.6 高斯光束.....................................................................................................................................36
1.6.1 高阶高斯光束......................................................................................................................36
1.6.2 高斯光束的传输变换..........................................................................................................41
1.6.3 高斯光束的干涉..................................................................................................................45
第二章 激光谐振腔......................................................................................................................... 60
2.1 激光谐振腔的本征方程.............................................................................................................60
2.2 无源腔的FOX-LI迭代方法.......................................................................................................60
2.3 无源腔的矩阵特征向量方法.....................................................................................................66
2.3.1 平行平面腔..........................................................................................................................67
2.3.2 双凹腔..................................................................................................................................71
2.4 基模谐振腔.................................................................................................................................78
2.4.1 高斯光束的ABCD定律与谐振腔.......................................................................................80
2.4.2 基模谐振腔的稳定性..........................................................................................................91
2.4.3 基模谐振腔设计实例..........................................................................................................97
2.4.4 基模谐振腔设计的逆向方法............................................................................................107
第三章 激光工程设计................................................................................................................... 118
3.1 速率方程的求解....................................................................................................................... 118
3.1.1 主动调Q速率方程的求解................................................................................................. 118
3.1.2 被动调Q速率方程的求解.................................................................................................125
3.1.3 脉冲泵浦速率方程的求解................................................................................................132
3.2 非线性激光光学.......................................................................................................................136
3.2.1 非线性晶体........................................................................................................................136
3.2.2 非线性晶体相位匹配........................................................................................................161
第四章 MATLAB数据与图像处理............................................................................................... 171
4.1 MATLAB图像处理应用...........................................................................................................171
4.1.1 自制特殊图形....................................................................................................................171
4.1.2 图像数据处理....................................................................................................................179
4.2 MATLAB数据处理应用...........................................................................................................197
4.2.1 批量数据处理....................................................................................................................197
4.3 MATLAB方程求解应用...........................................................................................................211
4.3.1 含参数非线性方程组的求解.............................................................................................211
【样品】Matlab辅助激光光学分析与应用(2014年 第三版).pdf (3.7 MB, 下载次数: 196)
《Matlab辅助激光光学分析与应用》第三版(2014年)_封面1.jpg 《Matlab辅助激光光学分析与应用》第三版(2014年)_封面2.jpg 《Matlab辅助激光光学分析与应用》第三版(2014年)_目录1.jpg 《Matlab辅助激光光学分析与应用》第三版(2014年)_目录2.jpg
《Matlab辅助激光光学分析与应用》第三版(2014年)_样品1.jpg 《Matlab辅助激光光学分析与应用》第三版样品2.jpg 《Matlab辅助激光光学分析与应用》第三版样品3.jpg 《Matlab辅助激光光学分析与应用》第三版样品4.jpg
该贴已经同步到 watermoon的微博
点评
关注: 5.0 技术: 5.0
推荐: 5.0
关注: 5 技术: 5 推荐: 5
支持原创作品,总比那些抄袭的所谓教授什么的写的好多了吧。  发表于 2014-6-30 10:51
发表于 2014-5-31 11:17:39 | 显示全部楼层
多少钱,买了!请给出联系方式,谢谢!
 楼主| 发表于 2014-5-31 12:28:49 | 显示全部楼层
121331768 发表于 2014-5-31 11:17
多少钱,买了!请给出联系方式,谢谢!
发表于 2014-6-15 16:26:13 | 显示全部楼层
很好,推荐。
发表于 2014-8-7 14:22:41 | 显示全部楼层
买了
 楼主| 发表于 2014-8-7 14:33:29 | 显示全部楼层
魅力薄膜 发表于 2014-8-7 14:22
买了
你没留下邮箱啊!?
发表于 2014-8-7 14:35:32 | 显示全部楼层
watermoon 发表于 2014-8-7 14:33
你没留下邮箱啊!?
不是书啊。。。185130054@qq.com
发表于 2014-8-26 08:08:42 | 显示全部楼层
不错啊,
发表于 2016-1-3 16:43:34 | 显示全部楼层
不错 感谢版主无私奉献 下下来看看
