查看: 2032|回复: 1
[产品] 法拉第镜参数与要求
发表于 2014-6-23 13:30:31 | 显示全部楼层 |阅读模式
Features
●        High Isolation
●        Low Insertion Loss
●        High Return Loss
●        Low Polarization Sensitivity
Applications
●        Optical Fiber Amplifiers
●        CATV Fiberoptic Links
●        Fiberoptic Systems Testing
●        Fiberoptic LAN Systems
●        Telecommunications
Performance Specifications
Parameter        Specification
Center Wavelength (nm)        1310,1480 or 1550
Min. Bandwidth(nm)        ±15
Typical Insertion Loss (dB)        0.4
Max. Insertion Loss (dB)        0.6
Faraday Rotation Angle (Single Pass)        45°
Rotation Angle Tolerance over Wavelength and Temperature        0.5°
Max. PDL (dB)        0.05
Max. PMD (dB)        0.05
Max. Optical Power (mW)        300
Max. Tensile Load (N)        5
Operation Temperature (℃)        -5 ~ +70
Storage Temperature (℃)        -40 ~ +85
Dimensions (mm)        Φ4.5x25 or Φ 5.5x30
Specifications may change without notice
Ordering Information
FRDMR        XX        X        X        X
        Center wavelength        Pigtail Style        Fiber Length        Connector
        13=1310nm
14=1480nm
15=1550nm        1=Bare Fiber
2=900um jacket        1=1m
S=Specify        0=none
1=FC/APC
2=FC/PC
3=SC/APC
4=SC/PC
5=ST
6=LC
吴海燕  132 6585 3433
珠海飞宇光电科科技有限公司(深圳业务中心)
地址:深圳市宝安区龙华鹊山路口太阳能硅谷大厦A座14楼
电话:0755-28113498-6037
传真:0755-29048624
Http://www.opticres.com
Emal:hywu@opticres.com
发表于 2014-7-19 17:13:36 | 显示全部楼层
