1×N Optical Switch
Features
•More Than 128Channels
•Low Loss and High Reliability
•arallel Interface (TTL)
•Modularized Design
•Epoxy-free on Optical Path
Application
•Ring Network
•Remote Monitoring in Optical Network
•Testing of Fiber, Optical Component
Specifications
Parameters FY-1×N
Insertion Loss dB 1<N≤45 45<N≤88 88<N≤128
Typ:0.8 Max:1.0 Typ:1.2 Max:1.5 Typ:1.7 Max:2.0
Wavelength Range nm 850±40/1300±40
850(SM) 12601650
12601620(SM)
Test Wavelength nm 850/1310
850 1310/1550
1310/1490/1550/1625
Return Loss dB SM≥50、MM≥30
Crosstalk dB SM≥55、MM≥35
PDL dB ≤0.05
WDL
dB dB ≤0.25
TDL dB ≤0.25
Repeatability dB ≤±0.05
Durability cycles ≥10 Million
Transmission Power mW mW ≤500
Switch Time ms ≤10(Sequence switch time of adjacent channel)
Operating Temperature C -20~+70
Storage Temperature C -40~+85
Power Supply V +5 or 12
Relative Humidity 5~+95
Dimension mm 1<N<4 (135×40×32) 4≤N≤12 (135×64×32) 12<N≤16(184×78×36)
16<N≤45(184×78×66) N≤<88 (184×156×66) 88≤N≤128(184×220×66)
N≤16(140×77.5×32) N≤32(140×77.5×64)
Ordering Information
Channel Mode Wavelength Voltage Type Fiber type Fiber diameter Fiber Length Connector
1~128 S=SM M=MM 85=850nm
13=1310nm
15=1550nm
162= 1625nm
165=1650nm
13/15=1310/1550nm 3=5V
5=12V 5=50/125
6=62.5/125
9=9/125
X= Other 25=250um
90=900um;
20=2.0mm
30=3.0mm
X= Other 05=0.5m
10=1.0m
15=1.5m
X=Other 0=None
1=FC/PC
2=FC/APC
3=SC/PC
4=SC/APC
5=ST/PC
6=ST/APC
7=LC/PC
8=LC/APC
X=Others
Pin Configurations
DB-9 male connector (max.1×16)
Pin No. Signal Name I / O Description
1 D0 Input TTL, Channel selection bit 0
2 D1 Input TTL, Channel selection bit 1
3 D2 Input TTL, Channel selection bit 2
4 D3 Input TTL, Channel selection bit 3
5 /RESET Input TTL, Low level reset to channel 0. High level means channel selection bits are effective.
6 /READY Output TTL, Ready (High=Not ready, Low=Ready)
7 ERROR Output TTL, Error (High=Error, Low=No error)
8 GND Input Ground
9 +5VDC Input 5.0±5% VDC Power Supply (max 550mA)
