查看: 1946|回复: 1
[产品] 温差黑体辐射源
发表于 2015-3-12 14:46:18 | 显示全部楼层 |阅读模式
Slew rate: +0.10°C/s, -0.08°C/s Rapid Settling Time
Stability: 0.005°C rms (±0.01°C p-p)
Emissivity: >0.95
Max/Min Temperature: 65°C / 5°C
Set point resolution: 0.01 °C
p
Differential Accuracy: 0.01 °C
Thermo-electrically driven blackbody provides
precise infrared emission over the MWIR and
LWIR spectral bands.
温差黑体应用于:
Measure Minimum Resolvable Temperature
Difference (MRΔT) of IR Imagers
• Ideal for Two-point Calibration of Infrared
Cameras and Detectors
• Removable/Interchangeable Bar Target
• Thermo-Electric Drive Provides Both Hot
and Cold Set-Point
&#8226; Achieves Set-point Temperature in < 1 Min.
&#8226; Faster and Easier Lab Calibration
需要详细资料可与我联系!
010-68914161
QQ:1150007178
 楼主| 发表于 2015-4-21 15:23:24 | 显示全部楼层
尺寸为:2*2英寸,
