<P>LD to single mode fiber coupling, you will have to use overlap integral to calculate the coupling efficiency. To multi-mode fiber, you could use NA and core diameter of the fiber to do the geometric ray tracing in ZEMAX and calculate the throughput of the coupling system.</P>
