查看: 4564|回复: 0
[资料] 激光诱导声信号通信技术的初步研究
发表于 2015-7-9 11:33:31 | 显示全部楼层 |阅读模式
作  者:赵中华[1] 辛海燕[2] 王晓宇[3]
Zhao Zhonghua, Xin Haiyan, Wang Xiaoyu (1. Department of Information and Communication, Guilin University of Electronic Technology, Guilin 541004, China  2. Department of Electronic Engineering, Guilin University of Aerospace Technology, Guilin 541004, China;  3. Department of Electronic Engineering, Naval University of Engineering, Wuhan 430033, China)
机构地区:[1]桂林电子科技大学信息与通信学院,广西桂林541004 [2]桂林航天工业学院电子工程系,广西桂林541004 [3]海军工程大学电子工程学院,湖北武汉430033
出  处:《红外与激光工程》 EI CSCD 2015年第44卷第3期 863-866页,共4页
Infrared and Laser Engineering
基  金:国家自然科学基金(61461014,51109217,51209210)
摘  要:构建了激光声实验测量系统,利用脉冲激光聚焦击穿水介质产生声信号,由水听器将声信号转换成电信号并送入数字存储示波器。分析了激光声信号的时频域数学模型,通过实验对单个激光声信号的时频域特征进行了研究,对激光声通信的信号调制方式进行了理论分析和实验验证。研究结果表明:激光声信号的脉宽约为20μs,其能量主要集中在200 k Hz内,这其中100~200 k Hz内的能量占到的比例大约有50%,通过对激光声信号进行幅度调制和频率调制,可以有效实现激光声通信过程。
Experimental system for laser-induced acoustic signals was built. Acoustic signal was induced by pulsed laser focusing into water. A hydrophone was used to convert acoustic signals into electric signals. The mathematic model for laser-induced acoustic signals in time domain was analyzed. Energy distribution of laser-induced acoustic signals in frequency domain was studied. The modulation method for communication based on laser-induced acoustic signal was theoretically studied and proved by experiments. The results are as follows: Pulse width of laser-induced acoustic signal is about 20 μs. The laser-induced acoustic signals have most of their energy concentrated within 200 k Hz, where half of that is between 100 k Hz and 200 k Hz. Magnitude modulation and frequency modulation are effective methods in communication based on laser-induced acoustic signal.
关键词:激光声信号 光击穿 频谱 声信号
laser-induced acoustic signal ; optical breakdown ; spectrum ; acoustic signal ;
激光诱导声信号通信技术的初步研究.pdf (262.91 KB, 下载次数: 0)
