查看: 2927|回复: 0
[技术] 米散射测风激光雷达单Fabry-Perot干涉仪鉴频系统
发表于 2015-7-9 20:07:50 | 显示全部楼层 |阅读模式
The single Fabry-Perot interferometer frequency analyzer for Mie wind Lidar
下载全文
米散射测风激光雷达单Fabry-Perot干涉仪鉴频系统.pdf (389.01 KB, 下载次数: 0)
作  者:杨娜[1] 杜军[2]
YANG Na,DU Jun(1. College of Electrical and Information Engineering, Heilongjiang Institute of Technology, Harbin 150050, China; 2. National Key Laboratory of Science and Technology on Tunable Laser, Harbin Institute of Technology, Harbin 150080, China)
机构地区:[1]黑龙江工程学院电气与信息工程学院,黑龙江哈尔滨150050 [2]哈尔滨工业大学可调谐激光技术国家级重点实验室,黑龙江哈尔滨150080
出  处:《黑龙江工程学院学报》 2015年第29卷第1期 36-41页,共6页
Journal of Heilongjiang Institute of Technology
摘  要:对非相干米散射多普勒测风激光雷达单Fabry‐Perot干涉仪双边缘鉴频系统进行理论研究。证明通过适当地降低此系统斜入射通道信号光的发散角可以有效地弥补其边缘曲线不对称产生的测量精度降低的缺陷,使其能够接近双Fabry‐Pero t干涉仪双边缘鉴频系统的测量精度。还证明此系统可以根据实际风速的需要调整其测量动态范围以获得更高测量精度,具有更高的灵活性。
The single Fabry‐Perot interferometer (FPI) double‐edge structure in incoherent Mie Doppler wind Lidar is investigated theoretically .It has proved that ,by reducing the divergence of nonzero angle beam of this structure appropriately ,the deficiency caused by the asymmetric edge curves can be made up effectively and can have approximate equal measurement accuracy with the double FPIs double‐edge structure .It also has proved that the Lidar system with this structure can tune the measuring dynamic range for wind velocity requirement to reach as high measurement accuracy as possible and has a strong adaptability .
关键词:非相干探测 测风激光雷达 鉴频系统 双边缘技术 Fabry-Perot干涉仪
non-coherent detection ; wind Lidar ; frequency discriminator ; double-edge technique ; Fabry-Perot Interferometer ;
