查看: 2594|回复: 0
[技术] 激光烧蚀羽流光学成像效果研究
发表于 2015-7-9 20:08:55 | 显示全部楼层 |阅读模式
激光烧蚀羽流光学成像效果研究
Research on the optical imaging of laser ablation plume
下载全文
激光烧蚀羽流光学成像效果研究 (1).pdf (1.46 MB, 下载次数: 0)
作  者:刘克非[1] 洪延姬[1] 叶继飞[2]
LIU Ke-fei, HONG Yan-ji, YE Ji-fei ( State Key Laboratory of Laser Propulsion & Application, Equipment Academy, Beijing 101416, China. Science and Technology on Scramjet Laboratory,  Hypervelocity Aerodynamics Institute of CARDC, Mianyang 621000, China)
机构地区:[1]装备学院激光推进及其应用国家重点实验室,北京101416 [2]中国空气动力研究发展中心超高速空气动力研究所高超声速冲压发动机技术重点实验室,四川绵阳621000
出  处:《物理实验》 2015年第35卷第3期 10-14页,共5页
Physics Experimentation
摘  要:使用YAG脉冲激光烧蚀固态POM聚合物和掺碳质量分数为5%的液态甘油混合物,形成羽流场。分别在相机镜头前添加滤光片以及在纹影系统中设置不同的刀口,观察对羽流场像的影响。实验结果表明:滤光片和暗场纹影均能够提高羽流纹影图像的显示效果。
The plume flow field was made using YAG pulse laser ablation of solid POM polymer and carbon doped glycerin liquid mixture (5% mass fraction) .By adding filter in front of the camera lens and setting different incision in the schlieren system , respectively , the influence of the plume flow field was observed .The experimental results showed that the filter and dark field schlieren could improve the display effect of the schlieren image .
关键词:纹影技术 激光烧蚀羽流 暗场纹影 滤光片
schlieren technique ;laser ablation plume ;dark field schlieren ;filter ;
