查看: 2876|回复: 0
[技术] 人造板厚度激光非接触测量研究
发表于 2015-7-9 20:55:29 | 显示全部楼层 |阅读模式
人造板厚度激光非接触测量研究
Non-contact Measurement of Wood-based Panel Thickness by Laser
下载全文
人造板厚度激光非接触测量研究.pdf (670.19 KB, 下载次数: 1)
作  者:祖汉松 张厚江 贺昌勇 周卢婧
ZU Han-song, ZHANG Hou-jiang , HE Chang-yong, ZHOU Lu-jing  (School of Technology ,Beijing Forestry University ,Beijing 100083 ,China)
机构地区:北京林业大学工学院,北京100083
出  处:《西北林学院学报》 CSCD 2015年第30卷第2期 221-226页,共6页
Journal of Northwest Forestry University
基  金:林业公益性行业科研专项(201304512)
摘  要:厚度是人造板重要参数之一,随着人造板工业的高速发展,对人造板厚度的测量精度和检测方法也提出了更高的要求。采用上下2台激光传感器对人造板厚度进行了静态和动态非接触测量试验研究,提出了上下2激光传感器间距的标定方法,认为人造板厚度激光非接触测量是完全可行的。在被测板材静止状态下,激光检测厚度与板材厚度实际值之间误差非常小;在板材移动状态下,可以实时得到板材激光检测厚度值。
Thickness is one of the most important parameters of wood-based panels.With the rapid development of wood-based panel industry,higher requirements are needed for the measurement precision and detection methods.In this paper,two laser sensors(up and down the panel)were adopted to carry out dynamic and static non-contact thickness measurement.The calibration method for the distance of two lasers was proposed.It was proved that when the panel was static,minor errors of the measurement was observed with actual values of thickness,with the mobile state of the panel,real-time measurement could be achieved,indicating that non-contact measurement of wood-based panel thickness was completely feasible.
关键词:人造板厚度 标定 静态测量 动态测量
本帖被以下淘专辑推荐:
