查看: 2695|回复: 0
[技术] 双队列控制的激光视觉焊缝跟踪系统研究
发表于 2015-7-9 21:03:47 | 显示全部楼层 |阅读模式
双队列控制的激光视觉焊缝跟踪系统研究
Research of welding seam tracking system using laser vision and double queues
下载全文
双队列控制的激光视觉焊缝跟踪系统研究.pdf (1.21 MB, 下载次数: 1)
作  者:王秀平[1,2] 白瑞林[1]
WANG Xiuping,BAI Ruilin( 1.Key Laboratory of Advanced Process Control for Light Industry (Ministry of Education), Jiangnan University, Wuxi, Jiangsu 214122, China 2.Wuxi Professional College of Science and Technology, Wuxi, Jiangsu 214028, China)
机构地区:[1]江南大学轻工过程先进控制教育部重点实验室,江苏无锡214122 [2]无锡科技职业学院,江苏无锡214028
出  处:《计算机工程与应用》 CSCD 2015年第2期 30-34页,共5页
Computer Engineering and Applications
基  金:江苏高校优势学科建设工程资助项目(PAPD); 江苏省产学研前瞻性联合研究项目(No.BY2012056); 江苏省自然科学基金(No.BK20141115)
摘  要:设计与实现了一套激光视觉引导的焊缝自动跟踪系统,包括系统的整体硬件构成和关键算法。在工业机器人末端安装激光视觉传感器构成焊缝跟踪系统的硬件部分。采用小波变换滤除焊缝图像噪声,采用改进的Steger算法和Hough变换方法提取激光条纹中心直线,进一步提取出焊缝位置。提出一种双队列控制策略,在采集的焊缝特征点的基础上进一步插值,从而实现激光视觉引导的焊缝自动与平滑跟踪。实验结果表明,该系统具有较好的跟踪精度,能满足工业实际需求。
It designs and realizes a set of laser vision guided automatic seam tracking system, including overall system structure and key algorithms. A laser vision sensor is installed at the end of an industrial robot. Wavelet transform is used to filter image noise and improved Steger algorithm and Hough transform method are applied to extract the laser stripe center line. Then the position of welding seam is located. A strategy of dual queues is put forward to control the movement of the manipulator, and a series of intermediate points among welding points are obtained by interpolation, so as to realize the automatic and smooth tracking of weld laser visual guide. The experimental results show the system has good tracking accuracy and can meet the industrial requirement.
关键词:激光视觉 图像处理 焊缝跟踪 双队列
laser vision ; image processing ; weld seam tracking ; dual queues ;
本帖被以下淘专辑推荐:
