查看: 2529|回复: 0
[技术] 激光熔覆制备高熵合金的研究现状及发展趋势
发表于 2015-7-9 21:09:10 | 显示全部楼层 |阅读模式
Research Progress and Development Trend of Laser Cladding for Preparing High-entropy Alloy Coating
下载全文
激光熔覆制备高熵合金的研究现状及发展趋势.pdf (1.03 MB, 下载次数: 1)
作  者:崔天晓 石岩
CUI Tianxiao, SHI Yan  ( College of Mechanical and Electrical Engineering, Changchun University of Science and Technology, Changchun 130022, China)
机构地区:长春理工大学机电工程学院,长春130022
出  处:《机械工程师》 2015年第2期 199-201页,共3页
Mechanical Engineer
摘  要:高熵合金具有高硬度、高耐磨性、高耐温性及耐腐蚀性,从而成为材料科学领域一个新的研究热点,而通过激光熔覆制备高熵合金的方法是最能达到其优越性能的制备方法之一。文中综述了高熵合金发展历史、组织研究现状、力学性能研究现状以及合金元素和微量元素(如Ti,A l,Si等)对高熵合金组织和性能的影响。在此基础上,提出了研究高熵合金组织性能的方向和途径,并对其应用前景做了分析和展望。
High entropy alloy has the advantages of high hardness,high abrasion resistance,high temperature resistance and corrosion resistance and thus become a new hot spot in materials science. Laser cladding preparation method is most likely to achieve these advantages of high-entropy alloy. This paper reviewed history and present situation of high-entropy alloy, and its metallographic structure ,mechanical properties ,and studied effect of alloy elements and trace elements (such as Ti,A1,Si) on the microstructure and properties. The research directions and approaches of the microstructure and properties of high-entropy alloy are proposed ,and its application prospects are analyzed.
关键词:激光熔覆 高熵合金 高熵作用 涂层
laser cladding ; high-entropy alloy ; high-entropy effect ; coating ;
本帖被以下淘专辑推荐:
