查看: 3369|回复: 0
[分享] Matlab编程法在测量氦氖激光波长实验数据处理中的应用探索
发表于 2015-7-9 21:10:58 | 显示全部楼层 |阅读模式
Exploration of Matlab Programming Method is Applied in the Data Processing of Measurement of He Ne Laser Wavelength in the Experiment
下载全文
Matlab编程法在测量氦氖激光波长实验数据处理中的应用探索.pdf (168.76 KB, 下载次数: 0)
作  者:夏雪琴
XIA Xue-qin (Zhejiang Ocean University,Zhejiang Zhoushan 316000)
机构地区:浙江海洋学院,浙江 舟山316000
出  处:《大学物理实验》 2015年第28卷第1期 66-68页,共3页
Physical Experiment of College
摘  要:使用新型的WSM-T-Ⅱ型台式迈克尔逊干涉仪可以测量氦氖激光波长,传统的数据处理方法是逐差法,计算量大,既繁琐又容易出错。用Matlab软件的编程法处理实验测得的数据,程序运行后可以直接得到氦氖激光波长及相应的误差分析,无需进行运算,准确而快捷,是大学物理实验教学中实验数据处理的一种新方法。
The use of WSM-T-type II desktop Michelson novel interferometer can measure the helium neon la-ser wavelength,the method of data processing is the traditional difference method,a large amount of calcula-tion,tedious and error prone. The measured data by programming method in the treatment of experimental Mat-lab software,running the program can be directly obtained from the analysis of He Ne laser wavelength and the corresponding error,no need of operation,accurate and fast,and it is a new method of experimental data pro-cessing of physical experiment teaching in university.
关键词:氦氖激光波长 Matlab软件编程法 实验数据处理 不确定度
He Ne laser wavelength ;Matlab software programming method ;experimental data processing ;un-certainty ;
