查看: 4010|回复: 0
[转载] 高功率紫外超短激光脉冲光束质量研究
发表于 2015-7-9 21:28:12 | 显示全部楼层 |阅读模式
高功率紫外超短激光脉冲光束质量研究
Beam Quality Research of High Power Ultraviolet Ultrashort Laser Pulse System
下载全文
高功率紫外超短激光脉冲光束质量研究.pdf (501.81 KB, 下载次数: 0)
作  者:苏恒毅 兰小飞 张骥 王雷剑 路建新 汤秀章
SU Heng-yi, LAN Xiao-fei, ZHANG Ji, WANG Lei-jian, LU Jian-xin, TANG Xiu-zhang (China Institute of Atomic Energy, P. O. Box 275-7, Beijing 102413, China)
机构地区:中国原子能科学研究院核技术应用研究所,北京102413
出  处:《原子能科学技术》 EI CSCD 2015年第49卷第2期 230-233页,共4页
Atomic Energy Science and Technology
基  金:973计划资助项目(2011CB808104)
摘  要:通过搭建传输和聚焦光学系统,采用CCD相机测量了高功率紫外超短脉冲激光系统的光束质量参数,如紫外种子光及其经过KrF准分子激光器放大后的焦斑光强空间分布、焦斑尺寸及极限衍射倍数β。结果表明,紫外种子光光束质量良好,β接近于1。经放大后,光束质量劣化,β达到6左右。经分析,光学元件的表面缺陷可能是导致光束质量下降的主要因素。
By means of building transmitting and focusing optical system,the beam quality of high power ultraviolet ultrashort laser pulse system was researched by using a CCD camera.Relevant parameters obtained from the measurement are the spatial intensity distribution,the size of focal spot and beam qualityβ-factor of the ultraviolet seed laser and the amplified pulse after its amplification by a KrF laser system.The result shows that the beam quality of the ultraviolet seed laser beam is good.β-factor is closed to 1.After amplification the beam quality worsens andβ-factor increases to about 6.Through analysis,surface defects of optical elements may be the major factor which leads to the degradation of the laser beam quality.
关键词:超短脉冲 KrF激光 光束质量评价
ultrashort pulse ; KrF laser ; beam quality evaluation ;
