查看: 3097|回复: 0
[技术] 激光制造的三维实体模型直接切片方法
发表于 2015-7-9 22:14:51 | 显示全部楼层 |阅读模式
激光制造的三维实体模型直接切片方法
The Direct Slice Method of Three Dimension Object Modeling by Laser Manufacturing
下载全文
激光制造的三维实体模型直接切片方法.pdf (779.75 KB, 下载次数: 3)
作  者:周惠群 吴建军
Zhou Huiqun,Wu Jianjun ( Northwestern Polytechnical University ,Xi'an 710072, China )
机构地区:西北工业大学现代设计与集成制造技术教育部重点实验室,陕西西安710072
出  处:《电加工与模具》 2015年第1期 47-49页,53页,共4页
Electromachining & Mould
摘  要:基于快速成形中激光制造的三维实体模型,将其分为满足误差要求的一系列层片。采用提取截面轮廓的方法,将轮廓分为线段、圆弧和自由曲线,储存为特定的数据文件格式,轮廓内部形成扫描区域,以实现快速成形的分层制造。
The Paper presented a method which divide 3D modeling into a series of layer that meeting deviation demand based on laser manufacturing of rapid prototyping. Taking advantage of the method about draw contour,the contour have been separated into line and circle and free curve ,and then,data file have been store up wiih given format. Scanning region has been formed in profile for layer manufacturing of rapid prototyping.
关键词:实体模型 切片 轮廓 快速成形
object model ; slice ; contour ; rapid prototyping ;
本帖被以下淘专辑推荐:
