查看: 2940|回复: 1
[技术] 自由曲面底板的LED光学设计
发表于 2015-7-10 16:40:46 | 显示全部楼层 |阅读模式
自由曲面底板的LED光学设计
Design of LED optical system based on the substrate with freeform surface
下载全文
自由曲面底板的LED光学设计.pdf (959.7 KB, 下载次数: 0)
作  者:陈颖聪[1,2] 尚胜[1,2] 罗婉霞[3] 陈津桥[1,2] 谢嘉宁[4]
Chen Yingcong, Wen Shangsheng, Luo Wanxia, Chen Jinqiao, Xie Jianing  (1. School of Materials Science and Engineering, South China University of Technology, Guangzhou 510640, China; 2. State Key Laboratory of Luminescence Materials and Devices, South China University of Technology, Guangzhou 510640, China;  3. Electricity Facilities Guangri Guangzhou Co., Ltd., Guangzhou 511447, China;  4. Department of Optoelectron and Physics, Foshan University, Foshan 528000, China)
机构地区:[1]华南理工大学材料科学与工程学院,广东广州510640 [2]华南理工大学发光材料与器件国家重点实验室,广东广州510640 [3]广州广日电气设备有限公司,广东广州511447 [4]佛山科学技术学院光电子物理学系,广东佛山528000
出  处:《红外与激光工程》 EI CSCD 2014年第43卷第9期 2947-2953页,共7页
Infrared and Laser Engineering
基  金:广东省科技厅重大科技专项(2011A080801016);广东省战略性新兴产业专项(2011A081301017,2012A080304012,2012A080304001);广州市科技计划项目(2013J4300021)
摘  要:提出了一种基于自由曲面底板的LED配光新方法,采用TracePro软件设计自由曲面并进行仿真分析。结果表明:将LED芯片直接贴装在带有自由曲面的底板上,可以获得较大的出光角度,半光强角达到60°,比传统反光杯的配光方式获得的半光强角增大25°。此外,通过这种新方法可获得高光效和高均匀照度的照明模式,在实现相同的目标平面平均照度时,总光通量比传统配光方式减少25%,照度的衰减减少了60%。通过调节自由曲面底板的形状进行配光,可根据需要获得不同的照明效果,实现高品质的LED照明。
A novel method for light distribution based on the substrate with freeform surface is proposed. The freeform surface substrate is designed and stimulated by using the TracePro software. The stimulation results show that a large luminous intensity angle can be achieved by adjusting the LED chips directly onto the substrate with freeform surface. The half-intensity angle is 60° , 25° bigger than using the tradition reflection cup. Furthermore, a lighting with high light efficiency and uniform illumination can be achieved by using this method. When a same average horizontal illuminance is created, it costs 25% less luminous flux and avoids 60% less luminous decay than using the traditional method. By adjusting the shape of the freeform surface to distribute the LEDs′ light, not only the other patterns of luminous effects are conveniently get, but also a high quality of LED lighting can be achieved.
关键词:非成像光学 自由曲面 一次配光 TracePro
non-imaging optics ; freeform surface ; first optical design ; TracePro ;
本帖被以下淘专辑推荐:
发表于 2015-12-10 09:21:00 | 显示全部楼层
自由曲面底板?感觉好新奇哦
