查看: 2394|回复: 0
[技术] 线性色散设计的光谱共焦测量技术
发表于 2015-7-10 16:45:23 | 显示全部楼层 |阅读模式
线性色散设计的光谱共焦测量技术
Chromatic confocal microscope with linear dispersive objective
下载全文
线性色散设计的光谱共焦测量技术.pdf (350.53 KB, 下载次数: 0)
作  者:刘乾 王洋 杨维川 袁道成
Liu Qian, Wang Yang, Yang Weichuan, Yuan Daocheng (Institute of Mechanical Manufacturing Technology, CAEP , P. O. Box 919-658, Mian yang 621900, China)
机构地区:中国工程物理研究院机械制造工艺研究所,四川绵阳621900
出  处:《强激光与粒子束》 EI CSCD 2014年第26卷第5期 52-57页,共6页
High Power Laser and Particle Beams
基  金:中国工程物理研究院科学技术发展基金项目(201080203026)
摘  要:研制了高精度的光谱共焦位移测量系统并完成相关测试。基于色差理论材料优化选择设计一种色差与波长成线性关系的色散物镜,有助于平衡系统在全测量范围的灵敏度。理论分析了系统参数对系统的影响规律,计算了针孔尺寸与系统的分辨率和信噪比的关系,给出了参数优化结果。利用设计的线性色散物镜和参数优化结果,构建了光谱共焦测量系统,完成了系统的校准、测试和应用研究。结果表明,系统的轴向测量范围达到1mm,分辨力优于0.5μm,全程测量误差小于2μm,符合设计要求。
We built a chromatic confocal microscope for micro metrology. Based on dispersive aberration principle and opti- mization of lens glasses, a dispersive objective was designed, of which the dispersive aberration was linear to wavelength. The lin- ear dispersive aberration could help to balance the sensitivity of chromatic confocal microscope. Designed dispersive objective is of large dispersive aberration, small longitudinal aberration and long working distance. Influence of system parameters on optical sectioning was analyzed and simulation results were exhibited. Chromatic confocal microscope was built, calibrated and tested. Experimental results show that the measuring range is 1 mm, the resolution is better than 0.5 btm and the measuring error in full range is less than 2μm. To test the performance of microscope, profile of standard height was scanned and thickness of transpar- ent plate was measured.
关键词:光谱共焦 光学设计 色差 精密测量 位移传感
chromatic confoeal microscopy ; lens designs chromatic aberrations precision metrologys displacementsensor ;
本帖被以下淘专辑推荐:
