查看: 3196|回复: 0
[技术] 成像角膜曲率计的光学设计
发表于 2015-7-10 16:51:23 | 显示全部楼层 |阅读模式
成像角膜曲率计的光学设计
Optical design of imaging keratometer
下载全文
成像角膜曲率计的光学设计.pdf (622.81 KB, 下载次数: 1)
作  者:何远清 刘永基 翟奕
HE Yuan-qing, LIU Yong-ji, ZHAI Yi ( Institute of Modern Optics, Nankai University, Tianjin 300071, China)
机构地区:南开大学现代光学研究所,天津300071
出  处:《中国光学》 2014年第7卷第6期 956-961页,共6页
Chinese Optics and Applied Optics Abstracts
基  金:国家自然科学基金资助项目(No.11104149)
摘  要:为了提高角膜曲率计的测量精度,借助于现代光电子技术,设计了一款高精度的成像角膜曲率计。系统包括环形物、一次成像系统、角膜、二次成像系统和CCD探测器。首先在ZEMAX软件中,设计了成像角膜曲率计的一次成像系统和二次成像系统,分别对两个成像系统进行优化设计;然后通过半透半反镜组将一次成像系统和二次成像系统拼接,组成成像角膜曲率计的光学系统,并对其进行整体的优化设计。最后,利用TracePro对所得的环形像进行模拟和分析。结果表明:所设计的成像角膜曲率计的测量范围约为30~60D(对应角膜曲率半径5.5~11mm),测量精度在角膜曲率半径7.8mm时达到0.072D。
An imaging keratometer by the aid of modem optoelectronic technology is proposed to improve the accuracy of measurement. The optical system consists of an annular object, a first imaging subsystem, a sec- ond imaging subsystem, and a CCD detector. First, the first imaging subsystem and second imaging subsystem are designed and optimized by ZEMAX, and two subsystems are connected by a semitransparent mirror. Then we perform optimization of the whole optical system of imaging keratometer. Finally, the simulation of the iXlu- ruination of the annular image is accomplished by TracePro. The result shows that the measurement range of this imaging keratometer is about 30D to 60D(5.5 mm to 11 mm in radius of curvature), and the accuracy is about O. 072D in the case of the radius of curvature of 7.8 mm.
关键词:角膜曲率计 成像系统 高精度
keratometer ; imaging system ; high accuracy ;
本帖被以下淘专辑推荐:
