查看: 2736|回复: 0
[技术] 双波段消热差红外鱼眼光学系统设计
发表于 2015-7-10 17:15:24 | 显示全部楼层 |阅读模式
双波段消热差红外鱼眼光学系统设计
Design of dual-band athermal infrared fisheye optical system
下载全文
双波段消热差红外鱼眼光学系统设计.pdf (226.58 KB, 下载次数: 4)
作  者:付跃刚 黄蕴涵 刘智颖
Fu Yuegang,Huang Yunhan,Liu Zhiying(Monitoring and Analysis Center, Changchun University of Science and Technology, Changchun 130022, China)
机构地区:长春理工大学测控分析中心,吉林长春130022
出  处:《红外与激光工程》 EI CSCD 2014年第43卷第10期 3329-3333页,共5页
Infrared and Laser Engineering
基  金:国家自然科学基金(61108044)
摘  要:双波段鱼眼红外光学系统可以获取中波和长波两波段的图像信息,同时由于其大视场的特性,可以大大增加目标信息获取范围。根据光学系统的设计要求对光学系统进行了设计,全视场196°,4.4~5.4μm/7.8~8.8μm波段内清晰成像,考虑到冷光栏的制冷效应,F#严格与冷光栏匹配,达到100%的冷光栏效应。推导了大视场被动消热差公式,通过对玻璃材料的优化选择,达到了双波段消热差,所设计的光学系统结构相对简单,成像质量较好,系统各个波段在-40~60℃的工作温度下实现了消热差,满足使用需求。
The dual-band infrared optical system can track the band informantion stretch from mid-wave infrared to long-wave infrared, which can greatly improved the information acquisition. A dual-band infrared optical system based on the compact principle was designed, the optical system can imaging clearly continuous from 4.4-8.8μm/17.8-8.8μm, the F# strictly matched with cold light bar that the cold light bar effect reached 100%. While the system using the passive athermal methods to get rid of temperature compensation problem and finally realized the dual-band of athermalization. The result shows that: the design of the system structure is relatively simple, and can get stable good imaging quality in continuous bands from -40℃ to 60℃, satisfying the requirements of a standard infrared thermal imager.
关键词:鱼眼透镜 双波段 消热差 光学设计
fisheye lens dual-band athermalization optical design ;
本帖被以下淘专辑推荐:
