查看: 3095|回复: 0
[技术] 一款车载镜头设计
发表于 2015-7-10 17:19:36 | 显示全部楼层 |阅读模式
一款车载镜头设计
Design of a Vehicle-Mounted Camera Lens
下载全文
一款车载镜头设计.pdf (2.34 MB, 下载次数: 20)
作  者:朱军彦 丁桂林
Zhu Junyan Ding Guiling (School of Mechanical Engineering, Jangsu University, Zhenjiang, Jiangsu 212013, China)
机构地区:江苏大学机械工程学院,江苏镇江212013
出  处:《激光与光电子学进展》 CSCD 2014年第51卷第10期 164-171页,共8页
Laser & Optoelectronics Progress
摘  要:为了满足汽车倒车需求,设计了一款结构简单、生产成本低廉的广角倒车镜头。镜头为4片式结构,第1片为玻璃,其余3片为塑料,使镜头满足在恶劣环境下工作的要求。镜头F数为2.8,水平视场为185°,且实验结果显示边缘视场畸变得到较好控制。设计的镜头已经开始量产。
In order to meet the needs of the backing-up lens in cars, a wide-angle lens has been designed. The lens has four elements, the first is a piece of optical glass, the other 3 elements are plastic, and the lens is able to work under bad conditions. The lens has an F number of 2.8, the horizontal field is 185 degrees, and the test showes that the off-axial distortion is corrected perfectly. Mass production of the lens has begun.
关键词:光学设计 广角镜头 车载系统 车载镜头
optical design ; wide-angle lens ; vehicle-mounted system ;
本帖被以下淘专辑推荐:
