查看: 3633|回复: 0
[技术] 红外双波段双视场消热差光学系统设计中消波段间色差条件(方法)的研究
发表于 2015-7-10 17:46:09 | 显示全部楼层 |阅读模式
Methods of Correcting Between-Band Chromatic Aberration in Infrared Dual-Band Dual-Field of View Athermalized Optical Design
下载全文
红外双波段双视场消热差光学系统设计中消波段间色差条件(方法)的研究.pdf (953.92 KB, 下载次数: 11)
作  者:曲锐 邓键
Qu Rui DengJian Southwest Institute of Technical Physics, Chengdu, Sichuan 610041, China
机构地区:西南技术物理研究所,四川成都610041
出  处:《光学学报》 EI CSCD 2015年第1期 363-369页,共7页
Acta Optica Sinica
摘  要:通过推导两个波段间由于色散特性差异导致的波段间色差,得到了描述波段间色散能力的波段间色差系数P,并结合光学系统光焦度方程、消色差方程和消热差方程,讨论了考虑材料波段间色散能力的消热差色差系统设计方法,完成了一个共光路红外双波段双视场光学系统的无热化设计。该系统F数为2、焦距为150 mm/50 mm、波长范围为3.7~4.8μm和7.7~10.3μm,共含有8片透镜,3个非球面,在-40℃~60℃温度范围内,各视场均具有较好的成像质量和冷反射特性。
The between-band chromatic dispersive power P is derived from the derivation of between-band chromatic aberration. A new achrothermal model considering the between-band chromatic aberration is prompted.Then, method of athermalized and multi-band zoom optical system is discussed. Based on this achrothermal model,a dual-band(MWIR/LWIR) dual-field of view optical system under the requirements of F=2, 150 mm/50 mm focal length, 3.7~4.8 mm and 7.7~10.3 mm waveband is designed with optical passive athermalization technology. The optical system, which consists of 8 lenses and 3 aspheric surfaces, has good image quality and Narcissus character at each field of view at-40 ℃~60 ℃.
关键词:光学设计 红外技术 双波段 双视场 消热差
optical design ; infrared technology ; dual-band ; dual-field of view ; athermalization ;
本帖被以下淘专辑推荐:
