查看: 4796|回复: 0
[资料] 准共轴多波长红外激光二极管的光束准直技术
发表于 2015-7-10 17:51:29 | 显示全部楼层 |阅读模式
Research on Quasi-Coaxial Beams Collimation Technique of  Multi-Wavelength Infrared Laser Diode
下载全文
准共轴多波长红外激光二极管的光束准直技术.pdf (1.99 MB, 下载次数: 2)
作  者:薛明晰[1] 陈志斌[1] 王伟明[1] 王晓燕[1,2]
Xue Mingxi Chen Zhibin Wang Weiming Wang Xiaoyan(1.College of Mechanical Engineering, Shijiazhuang New Technology Application Institute,  Shijiazhuang , Hebei 050003, China;2.The 13th Research Institute, China Electronics Technology Group Corporation,  Shijiazhuang , Hebei 050000, China)
机构地区:[1]石家庄机械工程学院新技术应用研究所,河北石家庄050003 [2]中国电子科技集团公司第十三研究所,河北石家庄050000
出  处:《中国激光》 EI CSCD 2014年第5期 42-48页,共7页
Chinese Journal of Lasers
基  金:总装人才战略工程专项资助基金(装政[2013]714号)
摘  要:提出了一种多波长红外激光二极管的封装结构,为了提高该二极管输出的860、905、1064nm(脉冲/单模)等多种波长激光光束的平行性,对该封装结构下几种光束的准直技术展开研究。通过对高斯光束在傍轴、离轴两种状态下的成像分析,总结并提出了一种“准共轴”激光光束的成像理论,在该理论基础上设计了多波长激光二极管的准直光学系统,并通过光学设计软件建立了相应的光路模型。在该光路模型指导下制备了多波长激光光源样机,并通过实验对该样机输出的“准共轴”光束的平行性进行验证。实验结果表明,该样机体积小、质量轻,其输出的“准共轴”光束覆盖了860、905、1064nm(脉冲/单模)等多种波长,并具备良好的平行性。
We present a packaging structure of multi-wavelength infrared laser diode and study the beams collimation techniques under this structure for improving beams parallelism of wavelengths at 860 rim, 905 nm and 1064 nm (pulse/single). By the imaging analysis of Gaussian beam in both paraxial and off-axial conditions, we summarize and present an imaging theory of "quasi-coaxial" laser beams. The collimating optical system is designed by this imaging theory, and corresponding optical paths are modeling by the optical-design software. A prototype of multi-wavelength laser source is prepared under the guidance of optical paths model, and the parallelisms of "quasi-coaxial" beams are tested by a verification experiment. The experimental results show that the "quasi-coaxial" beams of 860 nm, 905 nm and 1064 nm (pulse/single) have well parallelisms.
关键词:光学设计 激光二极管 多波长 准共轴 准直
optical design laser diode multi-wavelength quasi-coaxial ; collimation ;
