查看: 2801|回复: 0
[技术] 基于并行计算的实时数字全息显微镜
发表于 2015-7-10 20:14:15 | 显示全部楼层 |阅读模式
基于并行计算的实时数字全息显微镜
Real-time digital holographic microscopy based on parallel calculation
下载全文
基于数字全息层析的温度场三维检测方法.pdf (602.01 KB, 下载次数: 0)
作  者:李勇[1,2,3] 毛磊[1] 章海军[2] 马利红[3] 王辉[3]
LI Yong, MAO Lei , ZHANG Haijun , MA Lihong , WANG Hui ( 1. Ningbo Yongxin Optics Co. Ltd. , Ningbo 315040, China; 2. Department of Optical Engineering, Zhejiang University, Hangzhou 310017, China; 3. Institute of Information Opties, Zhejiang Normal University, Jinhua 321004, China)
机构地区:[1]浙江宁波永新光学股份有限公司,宁波315040 [2]浙江大学光电信息工程学系,杭州310017 [3]浙江师范大学信息光学研究所,金华321004
出  处:《激光技术》 CSCD 2015年第39卷第2期 152-156页,共5页
Laser Technology
基  金:国家自然科学基金资助项目(61205012)
摘  要:为了实现实时数字全息显微观测,采用数字全息并行算法达到实时再现要求。首先根据设计的数字全息显微镜光路结构,充分利用图像传感器空间带宽积,通过实时记录方案采集全息图、物光强及参考光强以消除0级;然后通过设计的并行再现软件,将采集到的图像均匀分割为4个区域,交由4个进程分别同时计算,每个进程实现对应区域的全息图再现后,将每个再现结果再均分成4个区域,并将对应区域重新组合成4组数据交由4个进程分别同时进行叠加,计算相位及强度;最后将4个进程计算得到的相位、强度重新拼接成完整的再现强度及相位图。结果表明,系统的数据采集和图像再现速度达到了18frame/s。该设计系统实现了实时全息显微观测。
For real-time measurement of digital holographic microscopy(DHM),a parallel algorithm was proposed.Firstly,real-time recording strategy was adopted to record hologram,intensity of object wave and intensity of reference wave according to light path of DHM. Zero-order of hologram was removed by this strategy. So,the product of spatial band-width of image sensor was efficiently utilized. Then,parallel reconstructing software was developed. The captured image was separated to four partitions and was sent to four procedures which run simultaneously. After the partitions were reconstructed by the corresponding procedure,each reconstructed result was separated to four regions. The corresponding regions were combined to four groups and were sent to four procedures for superposing and calculating phase and intensity. Finally,the whole phase and intensity map were obtained by merging four regions of phase and intensity. The experimental results reveal that the speed for image capture and hologram reconstruction is up to 18frame/s. Real-time measurement is realized with the proposed system.
关键词:全息 全息测量 数字再现 空间频谱分析
holography ; holographic measurement ; digital reconstruction ; spatial spectrum analysis ;
本帖被以下淘专辑推荐:
