查看: 2924|回复: 0
[技术] 基于希尔伯特变换的数字全息位相重构技术
发表于 2015-7-10 20:15:53 | 显示全部楼层 |阅读模式
基于希尔伯特变换的数字全息位相重构技术
Digital holographic phase reconstruction technology based on Hilbert transform
下载全文
基于希尔伯特变换的数字全息位相重构技术.pdf (1.13 MB, 下载次数: 0)
作  者:高亚飞[1] 郭海军[2] 宋修法[2] 于梦杰[1] 王华英[2]
GAO Yafei, GUO Haijun, SONG Xiufa, YU Mengjie, WANG Huaying ( 1. School of Information & Electronic Engineering, Hebei University of Engineering, Handan 056038, China; 2. College of Science, Hebei University of Engineering, Handan 056038, China)
机构地区:[1]河北工程大学信电学院,邯郸056038 [2]河北工程大学理学院,邯郸056038
出  处:《激光技术》 CSCD 2015年第39卷第2期 266-269页,共4页
Laser Technology
基  金:国家自然科学基金资助项目(61077001); 河北省自然科学基金资助项目(F2008000750;F2010001038); 河北省科技计划资助项目(09277101D); 河北省教育厅高等学校科学技术研究重点资助项目(ZH2011241)
摘  要:为了提高数字全息重构的精度,采用希尔伯特变换的方法对数字全息位相重构进行了理论分析和实验验证。首先利用傅里叶变换滤除全息图中的0级项,然后运用希尔伯特变换对已经滤除0级项的全息图实现90°相移,并构造出解析信号,从而可以求出物体的包裹位相,最后利用最小二乘法进行位相解包裹得到物体的真实位相;并将希尔伯特变换法与常规傅里叶变换法重构的实验结果进行了对比和分析,获得了标准偏差的对比数据。结果表明,该方法比常规傅里叶变换法重构精度要高。这一结果对提高位相重构的精度是有帮助的。
In order to improve the accuracy of digital holographic reconstruction,theoretical analysis and experimental verification of digital holographic reconstruction phase were made by using Hilbert transform. Firstly,the zero order item of the hologram was filtered through Fourier transform. Secondly,the hologram without zero order item was shifted 90° through the Hilbert transform so that the analytic signal was constructed and the object's wrapped phase was found. Finally,the object's real phase was obtained by using the least square method to unwrap the phase. The experimental results of Hilbert transform reconstruction and conventional Fourier transform reconstruction were compared. The data of the standard deviation was obtained and compared. The results indicate that the reconstruct precision of this method is higher than the conventional Fourier transform method. The research results are helpful to improve the precision of the phase reconstruction.
关键词:全息 位相重构 希尔伯特变换 傅里叶变换 解析信号 最小二乘
holography ; phase reconstruction ; Hilbert transform ; Fourier transform ; analytical signal ; least squares ;
本帖被以下淘专辑推荐:
