查看: 4681|回复: 0
[技术] 基于并行结构的相位恢复算法在全息激光投影中的应用
发表于 2015-7-10 20:41:29 | 显示全部楼层 |阅读模式
Application of phase recovery algorithm based on parallel architecture in holographic projection technology
下载全文
基于并行结构的相位恢复算法在全息激光投影中的应用 (1).pdf (640.22 KB, 下载次数: 0)
作  者:吴广志 张晗盛 茆文艺
WU Guang-zhi , ZHANG Han-sheng, MAO Wen-yi (China Satellite Maritime Tracking and Control Department, Wuxi 214431, China)
机构地区:中国卫星海上测控部,江苏江阴214431
出  处:《液晶与显示》 CSCD 2014年第29卷第6期 1010-1015页,共6页
Chinese Journal of Liquid Crystals and Displays
基  金:青年科学基金(No.61101182)
摘  要:全息激光投影技术相比传统图像显示技术有突出的优势。作为全息激光投影技术的关键图像处理算法——相位恢复算法,算法的收敛速率和精度都有待提高,在实际计算中它们的效果不够理想,甚至不能保证迭代过程总收敛到正确解。基于此,本文提出了基于并行结构的相位恢复算法(PGSGA)。该方法思路是对多个初值进行并行运算,不断"筛"出最优结果来对GS算法进行加速。仿真实验证明,该算法在收敛速率和恢复的灰阶图像质量等方面具有优越性。
Compared with conventional display technology,holographic projection technology has outstanding advantages.The phase retrieval algorithm is a key image processing algorithms in holographic projection technology.The constringency speed and precision of these algorithms need to be raised.The performance of the algorithms above are not satisfactory,sometimes they cannot even guarantee that the iterative process converges to the correct solutions.Then,this paper proposes a parallel architecture based on the phase recovery algorithm-Parallel Gerchberg-Saxton with Genetic Algorithm(PGSGA).Simulation has proved that the proposed algorithm PGSGA is better in convergence rate and the restoration quality by testing gray-scale image.
关键词:全息术 视频全息投影系统 相位恢复算法 纯相位全息图 GS算法
holography ; ViHPS ; phase retrieval algorithm ; phase-only hologram ; GS algorithm
本帖被以下淘专辑推荐:
