查看: 4934|回复: 0
[技术] 一种基于全息术的光学系统闭环像差补偿方法
发表于 2015-7-11 00:54:30 | 显示全部楼层 |阅读模式
A closed-lo op ab erration comp ensating metho d of optics system based on holography
下载全文
一种基于全息术的光学系统闭环像差补偿方法.pdf (1.85 MB, 下载次数: 3)
作  者:唐艳秋[1,2] 孙强[1] 赵建[1] 姚凯男[1,2]
Tang Yan-Qiu, Sun Qiang, Zhao Jian, Yao Kai-Nan 1) ( Changchun Institute of Optics, Fine Mechanics and Physics, Chinese Academy of Sciences, Changchun 130033, China)  2) (University of China Academy of Sciences, Beijing 100049, China)  ( Received 12 June 2014; revised manuscript received 23 July 2014 )
机构地区:[1]中国科学院长春光学精密机械物理研究所,长春130033 [2]中国科学院大学,北京100049
出  处:《物理学报》 CSCD 2015年第2期 151-158页,共8页
Acta Physica Sinica
基  金:国家高技术研究发展计划(批准号:2013AA03A116)、国家重大科学仪器设备开发专项(批准号:2013YQ14051702)和吉林省省科技厅项目(批准号:20140204030GX)资助的课题.
摘  要:提出了一种基于21单元变形镜与全息波前传感器的全息自适应光学系统,并对其像差校正能力进行了分析。首先描述了全息波前传感器基本原理,并在薄全息图近似下给出基于快速傅里叶变换算法的全息波前传感器数值模型;然后基于21单元变形镜的数值模型,分析了该变形镜的波前校正能力;在此基础上,数值模拟并实验验证了全息自适应光学系统对静态像差的闭环校正能力。
We propose a holographic adaptive optics system based on holographic wavefront sensor and 21-element deformable mirror, and analyze the wavefront correction ability of the system in this paper. The principle of holographic wavefront sensor is described, and its numerical model is provided by fast Fourier transform algorithm in the thin hologram approximation. Then, the wavefront correction ability of 21-element deformable mirror is analyzed with its numerical model. Finally, the aberration compensation of the system is simulated and an experimental device is set up to verify the feasibility of the proposed adaptive optics system.
关键词:自适应光学 全息术 波前传感器 变形镜
adaptive optics ;holography ;wavefront sensor ;deformable mirror ;
本帖被以下淘专辑推荐:
