查看: 7189|回复: 2
[技术] 像面数字全息显微系统的成像分辨率及成像特点
发表于 2015-7-11 01:00:58 | 显示全部楼层 |阅读模式
Resolution and characteristics of an image-plane digital holograph- ic microscopic system
下载全文
像面数字全息显微系统的成像分辨率及成像特点.pdf (1009.52 KB, 下载次数: 1)
作  者:宋修法[1] 廖薇[2] 于梦杰[2] 刘飞飞[2] 王华英[1,2]
SONG Xiu-fa , LIAO Wei , YU Meng-jie, LIU Fei-fei , WANG Hua-ying (1. College of Science, Hebei University of Engineering, Handan 056038,China; 2. School of Information & Electri- cal Engineering, Hebei University of Engineering, Handan 056038,China)
机构地区:[1]河北工程大学理学院,河北邯郸056038 [2]河北工程大学信息与电气工程学院,河北邯郸056038
出  处:《光电子激光》 EI CSCD 2014年第25卷第5期 1010-1017页,共8页
Journal of Optoelectronics·laser
基  金:国家自然科学基金(61077001,61144005)、河北省自然科学基金(F2010001038,F2012402051,F2012402028)、河北省科技支撑计划(09277101D,13210201D)和河北省教育厅科学研究重点(ZH2011241)资助项目
摘  要:为了实现高质量成像,通过对实际的像面数字全息显微系统(IPDHMS)点扩散函数的推导,分析了系统的成像分辨率决定因素及成像特点,给出了相应的实验结果。结果表明,IPDHMS的成像分辨率取决于显微物镜(M0)的成像分辨率和记录器件的像元大小,而与记录器件的光敏面尺寸无关;无论物体被照亮区域有多大,对全息图的记录和再现都没有影响;IPDHMS对成像区域中各点发出的通过MO的各种频率成分均能完整记录与再现,是一种优化的全息成像系统,利用该系统可以实现高质量成像与测量。实验结果证明了理论分析的正确性。
In order to improve image quality, the point spread functions of practical image-plane digital holographic microscopic system (IPDHMS) with both spherical and plane reference waves are derived. The imaging resolution and imaging characteristics are analyzed. The corresponding experimental investi- gations are conducted. The results show that the imaging resolution of IPDHMS depends on the imaging resolution of the microscopic objective (MO) and the pixel size,but independent of the photosensitive surface size of the CCD. The big size of the illuminated region of the test sample doesn't affect the re- cording and the numerical reconstruction of the hologram. All frequency components that pass through the MO of each point in the imaging area can be completely recorded and reconstructed. IPDHMS is an optimized holographic imaging system,which can achieve high-quality imaging. The experimental results demonstrate the validity of theoretical analysis.
关键词:像面数字全息显微(IPDHM) 点扩散函数 横向分辨率 位相测量
image-plane digital holographic microscopy (IPDHM) ; point spread function ; resolution ;phase measurement ;
本帖被以下淘专辑推荐:
发表于 2018-1-19 09:32:32 | 显示全部楼层
发表于 2018-3-16 11:16:43 | 显示全部楼层
