查看: 5095|回复: 1
[技术] 利用Zemax评估RC光学系统研究
发表于 2015-7-11 04:08:12 | 显示全部楼层 |阅读模式
利用Zemax评估RC光学系统研究
Study on estimating RC optical system by using Zemax
下载全文
利用Zemax评估RC光学系统研究.pdf (899.84 KB, 下载次数: 8)
作  者:吕占伟[1] 聂真威[2]
LU Zhanwei, NIE Zhenzvei   (1. Unit 91550 of PLA, Dalian 116023, China; 2. Changchun Institute o{ Optics, Fine Mechanics and Physics, Chinese Academy of Sciences, Changchun 130033, China)
机构地区:[1]中国人民解放军91550部队,辽宁大连116023 [2]中国科学院长春光学精密机械物理研究所,吉林长春130033
出  处:《光学仪器》 2014年第5期 413-415页,419页,共4页
Optical Instruments
摘  要:针对RC(里奇-克莱琴)光学系统主次镜都为双曲面且轴外视场像散较大的特点,需要对这类光学系统的加工和装调过程进行分析,以明确加工误差和测试失调量对光学系统的影响.利用干涉仪和光学设计软件Zemax,对这类光学系统的光学特性进行分析.通过测试波像差与Zemax模拟结果的比对,完成了对加工误差和失调量的准确判断.经过对加工误差和失调量的正确修改,使光学系统的性能达到设计要求.
RC (Ritchey-Chretien) optical system has hyperboloidal primary and secondary mirrors, and the off-axis field has large astigmatism. The processing and alignment of RC optical system has some particular characteristics. The influence of errors in the processing and alignment of RC optical system need analyzing. The traits in the processing and alignment are evaluated by using interferometer and software Zemax~ Comparing the tested wavefront with those simulated results of Zemax, the errors in the processing and alignment of an RC optical system are judged. After proper modifications of the processing errors and misalignments, the optical system meets the requirement of the design finally.
关键词:波前像差 Zemax RC光学系统
wave front aberration ; Zemax ; RC optical system ;
本帖被以下淘专辑推荐:
发表于 2015-8-9 09:16:20 | 显示全部楼层
大神,谢谢分享。。。。。。。。
