查看: 2674|回复: 0
[技术] Fe基合金带表面抛光工艺研究
发表于 2015-7-12 18:25:15 | 显示全部楼层 |阅读模式
Fe基合金带表面抛光工艺研究
Study of surface polishing technique on Fe-based alloy ribbons
下载全文
Fe基合金带表面抛光工艺研究.pdf (900.55 KB, 下载次数: 0)
作  者:张建强 王志坚 王芳平
ZHANG Jianqiang, WANG Zhijian, WANG Fangping ( School of Electronic Information and Electrical Engineering, Tianshui Normal University, Tianshui, Gansu 741001, China)
机构地区:天水师范学院电子信息与电气工程学院,甘肃天水741001
出  处:《贵州师范大学学报:自然科学版》 2015年第33卷第1期 108-112页,共5页
Journal of Guizhou Normal University(Natural Sciences)
基  金:天水师范学院中青年教师科研资助项目(No.TSA1324)
摘  要:利用磁力显微镜(MFM)观测了经机械抛光、电解抛光、机械兼化学腐蚀抛光的Fe73.5Cu1Nb3Si13.5B9合金带表面结构,研究了MEP法处理样品表面粗糙度和腐蚀时间之间关系,基于MFM对材料表面结构的要求,实验结果表明Fe基合金表面最佳抛光工艺为:在30℃恒温下将MEP法处理样品投于浓度为36%~38%盐酸溶液中腐蚀15min。
Surface structures of Fe73.5 Cu1Nb3 Si13.5 B9 alloy ribbons treated with mechanical polishing ( MP), electrolytic polishing ( EP), mechanical and etching polishing (MEP) methods are observed by Magnetic Force Microscopy (MFM). For MEP samples, the relationship between roughness (sa) and etching time (t) is discussed. Based on requirement of MFM for material surface structure, we suggest that the optimum polishing technique of Fe-based alloy ribbons for: under 30℃ constant tem- perature, put the MEP samples into the HCI solution (concentration of 36%--38% ) etching for 15 min.
关键词:MFM 抛光 腐蚀 粗糙度
magnetic force microscopy (MFM) ; polishing ; etching ; roughness ;
本帖被以下淘专辑推荐:
