查看: 4149|回复: 1
[技术] 凸球面抛光后置处理和虚拟仿真技术研究
发表于 2015-7-12 18:51:08 | 显示全部楼层 |阅读模式
凸球面抛光后置处理和虚拟仿真技术研究
Study on the Technology of Virtual Simulation and Post-Processing for Convex Spherical Surface Polishing
下载全文
凸球面抛光后置处理和虚拟仿真技术研究.pdf (1.06 MB, 下载次数: 1)
作  者:崔海龙 周林 张云飞 周丹晨
CUI Hai-long,ZHOU Lin, ZHANG Yun-fei, ZHOU Dan-chen (Institute of Mechanical Manufacturing Technology, China Academy of Engineering Physics, Mianyang Si- chuan 621900, China)
机构地区:中国工程物理研究院机械制造工艺研究所,四川绵阳621900
出  处:《组合机床与自动化加工技术》 2014年第8期 144-146页,151页,共4页
Modular Machine Tool & Automatic Manufacturing Technique
基  金:国家科技重大专项:高档数控机床与基础制造装备(2013ZX04006011)
摘  要:为了有效解决凸球面抛光的难题,文章通过UG/CAM实现了基于螺旋线算法的凸球面抛光轨迹的生成,并运用UG/Post Builder创建的后置处理文件将刀位轨迹转化为数控程序。基于UG/CAD与VERICUT完成虚拟机床和抛光刀具的建模,然后调用数控程序,最终实现凸球面抛光过程的仿真。仿真结果验证了文中规划的抛光轨迹的可行性,并能够有效检测抛光过程中的碰撞问题。
In order to solve the problem of convex spherical surface polishing,the generation of polishing path for convex spherical surface based on the algorithm of spiral was achieved by UG /CAM software. The polishing path was converted into the NC program by using the post-processing files created by UG /Post Builder. The model of virtual machine and polishing tool was completed by using the software of UG /CAD and VERICUT. Ultimately,the simulation of convex spherical polishing process was achieved by calling the NC program. Simulation results verify the feasibility of the polishing path generated in this paper,and the problem of collisions in polishing process can be detected effectively.
关键词:凸球面抛光 后置处理 虚拟仿真
convex spherical surface polishing ; post-processing ; virtual simulation ;
本帖被以下淘专辑推荐:
发表于 2016-2-21 12:56:27 | 显示全部楼层
太深奥了,不太了解这理论东东呃
