查看: 3056|回复: 0
[技术] 不同抛光工具对不同类型复合树脂表面微观结构的影响
发表于 2015-7-12 18:51:41 | 显示全部楼层 |阅读模式
The effects of different polishing instruments on the microstructure of different tipes of composite resins
下载全文
不同抛光工具对不同类型复合树脂表面微观结构的影响.pdf (1.16 MB, 下载次数: 0)
作  者:孙磊[1] 徐基亮[1] 陈漪恺[2] 刘春[1] 夏荣[1]
SUN Lei, XU Jiliang, CHEN Yikai, LIU Chun, XIA Rong( 1. 230601 Hefei, Department of Stomatology, The Second Hospital of Anhui Medical University, China; 2. Anhui Key Laboratory Optoelectronic Science and Technology, Hefei)
机构地区:[1]安徽医科大学第二附属医院口腔科,合肥230601 [2]安徽省光电子科学与技术重点实验室,合肥230601
出  处:《实用口腔医学杂志》 CSCD 2014年第30卷第5期 629-632页,共4页
Journal of Practical Stomatology
基  金:安徽省科技厅年度重点科研资助(编号:11070403063);安徽医科大学校科学研究基金(编号:2013xkj036)
摘  要:目的:探讨抛光工具对树脂表面微观结构的影响并与离体天然牙釉质表面进行比较。方法:将5种树脂试件(n=9)随机各分为3组(n=3):Astropol抛光(A)组、Sof-Lex抛光(B)组、Super-snap抛光(C)组,分别进行抛光,对照(D)组为离体牙釉质表面。原子力显微镜测试试件表面粗糙度和微观结构。结果:抛光后A组的Ra值低于B组(P=0.015);Z350XT树脂抛光后获得的Ra值最低(P<0.05);用3种不同的抛光工具抛光5种不同的树脂与对照组的Ra值比较无统计学差异(P>0.05)。结论:Astropol抛光工具效果优于Sof-Lex;Z350XT与其它4种树脂相比有更好的抛光性能;3种抛光工具对5种树脂抛光均有效。
Objective:To evaluate the effect of different polishing instruments on the microstructure of composite resin.Methods:Specimens of 5 kinds of resins were randomly divided into three groups and were polished with Astropol(group A),Sof-Lex(group B) and Super-snap(group C)respectively(n=3 for each resin).Specimens of natural enamel surface were used as the controls(group D).The surface roughness(Ra)and microstructure of the specimens were evaluated by an atomic force microscope(AFM).Results:Ra value in group A was lower than that in group B(P=0.015);Z350 XT resin obtained the lowest Ra value among the 5 kinds of resin specimens(P〈0.05).All of the resin specimens had similar average Ra after polishing procedure(P〉0.05).Conclusion:Astropol polishing instrument is better than Sof-Lex;Z350 XT has better polish performance.The three polishing instruments are ef-fective in polishing the 5 composite resins.
关键词:复合树脂 抛光 表面粗糙度 微观结构 牙釉质
Composite resin olishing ;Surface roughness ;Microstructure ;Enamel ;
