查看: 6644|回复: 4
[技术] 在双抛机上实现板材单面抛光的加工技术
发表于 2015-7-12 18:54:18 | 显示全部楼层 |阅读模式
在双抛机上实现板材单面抛光的加工技术
Glass plate unifacial-polished technique realized at  double-faced polished machine
下载全文
在双抛机上实现板材单面抛光的加工技术.pdf (853.94 KB, 下载次数: 56)
作  者:郭卫东
GUO Weidong (LIDA Optical and Electronic Co. , Ltd. , China Optics Group, Nanyang 473003, Henan, China)
机构地区:中光学集团利达光电股份有限公司,河南南阳473003
出  处:《光学技术》 CSCD 2015年第2期 177-180页,共4页
Optical Technique
摘  要:目前在光学冷加工市场有一定量的单面抛光板材的需求量,由于这种零件大多在要求只有一个面抛光的同时,对抛光面的面型有较高的要求,采用传统的粘接剂上盘在单轴抛光机上进行单面抛光的方法,由于拆胶后零件的应力变形,无法得到要求较高的面型。双面抛光技术由于两个面同时加工,可以很好地消除抛光面的应力问题,因此在薄板型零件加工中可以得到较好的面型,但只能得到双面同时抛光的零件。介绍了几种在双面抛光机上实现高面型精度要求的单面抛光板材的加工方法。
At present, there is a definite quantity of the demand of unifacial polishing glass-plate in optical cold working market. It has a higher requirement for the planeness of the polishing surface while such component is generally required to polish only one surface, so it is impossible to polish the perfect planeness using the traditional method of putting the components in the tray with the adhesive and polishing one surface at uniaxial polishing machine because of the stress deformation of the component after removing the glue. The double-faced polishing technique can eliminate the stress of the polishing surface efficiently due to processing the two surfaces simultaneously. Therefore, it can get better planeness with this method during the thin-plate processing, hut only get the double-faced polished component. The several processing methods that can satisfy the high precision requirement of the planeness for unifacial polishing glass-plate at double-faced polishing machine are introduced.
关键词:双面抛光机 单面抛光 薄板型零件
double-faced polishing machine ; unifacial polishing ; thin-plate type of the component ;
本帖被以下淘专辑推荐:
发表于 2016-2-21 12:33:42 | 显示全部楼层
好东东,谢谢分享!光学加工真是好多东西要学
发表于 2016-2-21 12:55:12 | 显示全部楼层
这种材料容易出刀子和亚克,机床清洗干净,研磨粉要浓度低
发表于 2016-3-22 01:20:36 | 显示全部楼层
谢谢,还有关于双面抛机理的资料吗!我之前有过!但是在清理电脑时洗掉了!太可惜了!就是运动轨迹方面的!
发表于 2016-10-6 22:53:12 | 显示全部楼层
以前听说可以用两片叠在一起抛光,不知道楼主的方法是啥
