查看: 6601|回复: 2
[技术] 蓝宝石衬底双面研磨亚表面损伤双片式角度抛光法检测
发表于 2015-7-12 19:13:40 | 显示全部楼层 |阅读模式
Double-substrate angle polishing to detect the damage on  sapphire substrate body after double-grinding
下载全文
蓝宝石衬底双面研磨亚表面损伤双片式角度抛光法检测.pdf (1.4 MB, 下载次数: 1)
作  者:徐晓明[1,2] 刘道标[2] 周海[2] 卓志国[1,2] 臧跃[2,3]
Xu Xiaoming, Liu Daobiao, Zhou Hai, Zhuo Zhiguo, Zang Yue ( 1 Changzhou University, Changzhou 213016, Jiangshu, China ;2 Yancheng Institute of Technology,  Yancheng 224051, Jiangshu, China; 3 Jiangsu University, Zheniiang 212013. Jiangshu. China)
机构地区:[1]常州大学,常州213016 [2]盐城工学院,盐城224051 [3]江苏大学,镇江212013
出  处:《现代制造工程》 CSCD 2014年第5期 118-122页,36页,共6页
Modern Manufacturing Engineering
基  金:江苏省自然科学基金项目(BK2008197);江苏省高校科研成果产业化推进项目(JH10-X048);江苏省新型环保重点实验室开放课题基金项目(AE201120);江苏省生态环境材料重点建设实验室开放课题资助项目(EML2012013);国际科技合作聘专重点资助项目
摘  要:针对传统角度抛光法检测的不足,提出将双片式角度抛光法用于蓝宝石衬底双面研磨亚表面损伤层深度的检测。双片式角度抛光法采用双晶片重合黏结的实验晶片组测量抛光斜面腐蚀裂纹,避免了传统角度抛光法因抛光斜面和原晶片平面分界边缘难以辨别而造成的测量误差;使用数显测长仪对实验晶片组抛光斜面加工轮廓进行测量,测量结果代入相应计算公式得出准确的斜面倾角,消除角度取值不准确带来的方法误差,提高了测量精度。经检测得到,单晶面抛光斜面平均裂纹宽度约为175μm、平均斜面倾角为4.91°,双面研磨单晶面亚表面损伤层深度约为15μm,双晶面亚表面损伤层深度约为30μm。双面研磨工艺参数:研磨液采用320#碳化硼磨粒煤油溶液,研磨初始压力为30g/cm2,研磨终止压力为110g/cm2,研磨盘转速为13r/min。
Present a new way to detect the damage on sapphire substrate after grinding to avoid the defect of traditional way. The way makes a test-specimen which is made of two adherent substructs to test the deep of damage on inclined plane after polishing, avoid the mistake of polished inclined plane and the edge of substrate plane, this mistake can bring error in investing, the size of test-specimen can be obtained with digital length measurement, so calculate the accurate results with these number and dispel the method error drag-in during testing, the accuracy of measurement is improved to nanoscale. In the experiment, the damage of pol- ishing cant of single substrate is 175μm, bevel angle is 4.91°, from these, obtain that the accurate depth of damage in one of the substrates is 15μm after two-sided lapping and the total depth of the double is 30μm. The technological parameter:320# boron carbide abrasive,the initial pressure is 30g/cm2 ,end pressure is 110g/cm2 ,rotate speed of polishing disc is 13r/min.
关键词:角度抛光 蓝宝石 衬底基片 双面研磨 亚表面损伤 裂纹 斜面倾角
angle polishing ; sapphire ; substrate body ; double-sided grinding ; subsurface damage ; crack ; slant angle ;
本帖被以下淘专辑推荐:
发表于 2020-9-11 21:29:46 | 显示全部楼层
发表于 2020-9-13 09:22:32 | 显示全部楼层
