查看: 3376|回复: 0
[技术] 高激光损伤阈值化学膜透射元件的研制
发表于 2015-7-12 19:14:41 | 显示全部楼层 |阅读模式
激光损伤阈值化学膜透射元件的研制
Preparation of Transmissive Optics Coated by Sol-gel Method With High Laser-induced Damage Threshold
下载全文
高激光损伤阈值化学膜透射元件的研制.pdf (864.59 KB, 下载次数: 1)
作  者:李晓光[1,2] 张清华[3] 沈军[1,2]
LI Xiao-guang , ZHANG Qing-hua , SHEN Jun (1. School of Physics Science and Engineering, Tongji University, Shanghai 200092, China 2. Shanghai Key Laboratory of Special Artificial Microstructure Materials and Technology,  Tongji University, Shanghai 200092, China ;  3. Chengdu Fine Optical Engineering Research Centre, Chengdu 610041, China)
机构地区:[1]同济大学物理科学与工程学院,上海200092 [2]同济大学上海市特殊人工微结构材料与技术重点实验室,上海200092 [3]成都精密光学工程研究中心,四川成都610041
出  处:《原子能科学技术》 EI CSCD 2014年第48卷第4期 763-768页,共6页
Atomic Energy Science and Technology
基  金:上海市科委纳米专项资助项目(11nm0501600);国家自然科学基金委员会和中国工程物理研究院联合基金资助项目(U1230113);国家科技支撑计划资助项目(2013BAJ01B01)
摘  要:以K9和熔石英玻璃为基底结合溶胶-凝胶镀膜技术,制备了用于负载1 064nm和355nm激光辐射的高损伤阈值透射玻璃元件。综合考虑基底表面和亚表面质量及薄膜质量,系统分析了影响激光损伤阈值的因素,并通过基底加工与薄膜改性的结合大幅提高了元件的损伤阈值。在薄膜改性方面,采用溶胶内添加聚乙二醇和氨气氛处理相结合的方法,使薄膜的结构缺陷减少,孔径分布更合理,所得薄膜的抗激光损伤能力远大于未处理的基底的。在基底加工方面,采用超级抛光和化学腐蚀的方法获得了超光滑表面和低缺陷亚表面,使用于红外波段的K9玻璃和紫外波段的熔石英玻璃的激光损伤阈值分别提高到原来的1.3和4.1倍。将上述改性后的薄膜镀在改性后的基底上,所得透射元件的激光损伤阈值不小于相应基底的。
Transmissive optics with high laser-induced damage threshold(LIDT)were prepared,with K9and silica glass as substrates that were coated with sol-gel porous silica coatings,for 1 064nm and 355nm laser irradiation.The factors that effect LIDT were systematically analyzed considering both the coating and substrate qualities.The LIDTs of the optics substantially increase by combining the substrate treating and film modification.The film modification was realized by two steps,that is,modifying thesilica sol with polyethylene glycol and coating with ammonia treatment.The film eventually features less structural defects and better uniformity,and presents stronger ability of resisting laser damage than the substrate without any treatment.As for the substrate treatment,chemical etching and super-polishing were employed to obtain super smooth surface and less-defects subsurface,which resulted in an increase in the LIDT of K9glass(at 1 064nm)by 1.3times and that of silica glass(at 355nm)by 4.1times.The LIDTs of this optics don’t decrease after the treated glass were coated with the modified films,meaning that the LIDTs of the modified films are high enough to match the treated substrates.
关键词:激光损伤 二氧化硅薄膜 溶胶-凝胶 超级抛光
laser-induced damage ;silica coating ;sol-gel ;super-polishing ;
本帖被以下淘专辑推荐:
