查看: 4087|回复: 0
[资料] CeO2/SiO2复合磨粒抛光性能及机制研究
发表于 2015-7-12 19:27:54 | 显示全部楼层 |阅读模式
Research on Polishing Performances and Mechanisms of CeO2/SiO2  Composite Abrasives
下载全文
CeO2/SiO2复合磨粒抛光性能及机制研究.pdf (315.84 KB, 下载次数: 0)
作  者:张强 黄国栋 赵永武 赵元元 王永光
Zhang Qiang Huang Guodong Zhao Yongwu Zhao Yuanyuan Wang Yongguang(College of Mechanical Engineering, Jiangnan University,Wuxi Jiangsu 214122, China)
机构地区:江南大学机械工程学院,江苏无锡214122
出  处:《润滑与密封》 CSCD 2014年第39卷第1期 59-63页,共5页
Lubrication Engineering
基  金:基金项目:国家自然科学基金项目(51005102);中央高校基本科研业务费专项基金项目(JUSRP10909;JUDCF13028);清华大学摩擦学国家重点实验室开放基金项目(SKLTKE10804);教育部留学回国人员科研启动基金项目(20111139);江苏省普通高校研究生科研创新计划项目(CXZZ13_0738).
摘  要:为提高硅片抛光质量与效率,利用均相沉淀法制备CeO2/SiO2复合磨粒,配制绿色环保水基型抛光液对硅片进行化学机械抛光,研究pH值、抛光时间、抛光速度、抛光压力等抛光工艺参数对硅片抛光性能的影响。结果表明:随抛光液pH值增加,材料去除率相应增大;材料去除率在一定时间范围内随抛光时间增加而下降;材料去除量随抛光速度、抛光压力的增加均先增大后减小。推测CeO2/SiO2复合磨粒抛光机制为由于水合作用,在硅片表面形成一层易于磨削的软质层。
In order to improve the quality and efficiency of wafer chemical mechanical polishing(CMP) ,the green water-based slurry was prepared by CeO2/SiO2 composite abrasives with homogeneous precipitation, and the polishing per-formance of CeO/SiO2 composite abrasive slurry on silicon wafer was studied by changing pH value of polishing slurry, polishing time, polishing speed and polishing pressure. The results show that the material removal rate is increased with the increasing of pH value of polishing slurry, and decreased with time within a certain polishing time. With the increasing of polishing rate and polishing pressure, the amount of material removal is increased first and then decreased. The polishing mechanism of CeO/SiO2 composite abrasive slurry is that the soft layer easy for grinding is formed on wafer surface by CeO2/SiO2 composite abrasives due to the hydration.
关键词:化学机械抛光 复合磨粒 抛光工艺参数 硅片 抛光机制
chemical mechanical polishing ; composite abrasives ; polishing process parameters ; silicon wafer ; polishing mechanism ;
本帖被以下淘专辑推荐:
