查看: 4082|回复: 0
[技术] 进动气囊抛光工艺参数研究
发表于 2015-7-12 19:47:36 | 显示全部楼层 |阅读模式
进动气囊抛光工艺参数研究
Research on Polishing Parameters of Bonnet Polishing
下载全文
进动气囊抛光工艺参数研究 (1).pdf (290.93 KB, 下载次数: 0)
作  者:张利鹏 杨辉 鲍龙祥
ZHANG Li-peng, YANG Hui, BAO Long-xiang (Aviation Key Laboratory of Science and Technology on Precision Manufacturing,  Beijing Precision Engineering Institute For Aircraft Industry, Beijing 100076)
机构地区:北京航空精密机械研究所精密制造技术航空科技重点实验室,北京100076
出  处:《航空精密制造技术》 2014年第1期 5-8页,共4页
Aviation Precision Manufacturing Technology
摘  要:为了提高光学元件的面形精度,提高加工效率,针对平面光学零件,以抛光去除效率和表面粗糙度为考核指标,对影响进动气囊抛光的几个工艺参数进行了正交试验及分析,得出各工艺参数对抛光去除效率和表面粗糙度的影响规律。确定最佳工艺参数,并在此条件下进行了气囊抛光工艺试验,通过Matlab软件拟合出了气囊抛光去除函数,为开展驻留时间的计算和面形控制提供了依据。
In order to improve the surface accuracy and processing efficiency of optical element, the orthogonal experiment by the processing parameters that influence bonnet polishing is made with the influence to the removal efficiency and surface roughness on the plane optical work-pieces. The result is discussed and analyzed according to bonnet polishing mechanism and material removal mechanism. The optimization parameters of bonnet polishing optical glass is got. Through the experiments integrated process parameters, the removal function of precession bonnet polishing is fitted by Matlab. This also makes it convenience for the later work like the solution of resident time and the surface control.
关键词:气囊抛光 正交试验 去除效率 表面粗糙度 去除函数
bonnet polishing ;orthogonal experiment ;removal efficiency ;surface roughness ;removal function ;
本帖被以下淘专辑推荐:
