查看: 3353|回复: 1
[技术] 高温真空镀膜夹具的设计
发表于 2015-7-12 21:29:05 | 显示全部楼层 |阅读模式
高温真空镀膜夹具的设计
HIGH TEMPERATURE COATING JIG
下载全文
高温真空镀膜夹具的设计.pdf (1.12 MB, 下载次数: 30)
作  者:周斌
ZHOU Bin(Xinhua Precision-Machined Electronic Company,Guangdong Huizhou 516001)
机构地区:信华精机有限公司,广东惠州516001
出  处:《真空与低温》 2015年第1期 59-61页,共3页
Vacuum and Cryogenics
摘  要:对于要求整面镀膜的大规格玻璃面板,镀膜环境为高温的情况下,采用传统夹子夹持的方法,不能满足大规格玻璃整面镀膜的需要.提出一种新的思路,并设计了新夹具解决此问题.应用玻璃基片及金属材料热膨胀系数不同的特性,设计铝合金与耐热钢组合的夹具抵消高温引起的变形,利用玻璃基片的倒边来支承玻璃.
For the surface coating is large size glass panel,and in the case of deposition environment is high temperature,the traditional clip clamping method is not applicable. In this paper,a new way has been provided and a new fixturehas been disigned to solve this problem. Using the diffrent characteristics of glass substrate and metal material thermal expansioncoefficient,the fixture has been disigned by alumiunm alloy and heat resistant combinational steel,and it counteracteddeformation caused by high temperature. Inverse side of the glass substrate was used to support the glass.
关键词:热胀冷缩 高温真空镀膜 大规格基片
heat dilatation cold shrinkage ;high temperature coating ;large-plane substrate ;
本帖被以下淘专辑推荐:
发表于 2015-8-25 20:03:44 | 显示全部楼层
好东西要顶一下。
