查看: 2639|回复: 0
[技术] 石英基片精密干冰清洗效果的红外光谱差示法
发表于 2015-7-12 22:21:49 | 显示全部楼层 |阅读模式
Infrared differential spectroscopy research of fine CO2 jet spray cleaning organic compound on silica substrate
下载全文
石英基片精密干冰清洗效果的红外光谱差示法.pdf (1.16 MB, 下载次数: 0)
作  者:张哲 潘峰 唐明 陈松林
Zhang Zhe, Pan Feng, Tang Ming, Chen Songlin (Chengdu Fine Optical Engineering Research Center, Chengdu 610041, China)
机构地区:成都精密光学工程研究中心,成都610041
出  处:《强激光与粒子束》 EI CSCD 2014年第26卷第11期 55-62页,共8页
High Power Laser and Particle Beams
基  金:国家高技术发展计划项目
摘  要:使用红外透过差示光谱法,对低羟基石英基片上的有机物吸收峰进行了定量测量表征.从理论上研究了该方法的可行性和特点,并初步检验了该方法的灵敏度.利用这种手段采集了大量真空精密干冰清洗石英基片的数据,统计发现这些数据能够体现一定的规律性:干冰清洗有机物的效果与原始污染状况紧密联系,某一时刻污染物越多,清洗效率越高;无机物或大颗粒的混入会降低有机物清洗效率;表面形态也能够影响清洗效率.这些成果证明了该定量表征方法的正确性和实用性.实验过程和所得结论表明,将清洗初始状态控制在相对一致的状态下,是精密干冰清洗定量研究和工程化参数优化的一个重要因素.
A given kind of silica substrates,which low hydroxy group is contained by,was made (quantitative analysis) by the way of infrared differential spectroscopy.Some characteristic absorption peaks of methylene and methyl were measured as a measurement of organic compound.As many data before and after fine CO2 jet spray cleaning were obtained,some rules appeared statistically.Cleaning rate connects to the polluted degree.The higher the polluted degree is,the faster the cleaning rate is.Cleaning rate can also be reduced by the mixture of mineral and big particles.Furthermore,topography affects cleaning rate,too.All of them support the research method,and the process and results claim that for research and production process optimization,it is very important to find a way to insure the consistency of polluted degree on the surface before fine CO2 jet spray cleaning.
关键词:红外光谱 干冰清洗 差示光谱法 傅里叶变换光谱仪 光学镀膜
infrared spectroscopy ; CO2 jet spray cleaning ; differential spectroscopy ; Fourier transform infrared spectroscopy ; optical film ;
本帖被以下淘专辑推荐:
