查看: 4149|回复: 2
[技术] 基于实例推理的镀膜机快速设计研究
发表于 2015-7-12 22:26:57 | 显示全部楼层 |阅读模式
基于实例推理的镀膜机快速设计研究
Case-based Reasoning in Rapid Design of Coater
下载全文
基于实例推理的镀膜机快速设计研究.pdf (344.55 KB, 下载次数: 16)
作  者:贾礼凤 仲梁维
JIA Li-feng, ZHONG Liang-wei (University of Shanghai for Science and Technology, Shanghai 200093, China)
机构地区:上海理工大学,上海200093
出  处:《包装工程》 CSCD 2014年第35卷第19期 73-76页,92页,共5页
Packaging Engineering
摘  要:目的 研究大规模定制模式下镀膜机的快速设计方法。方法 阐述了基于实例推理技术的基本原理和关键技术,将基于实例推理的快速设计技术应用到镀膜机的设计过程中;研究了镀膜机的实例表示、检索和修正的具体实现方法,即采用数据库表的实例表示方法构建了镀膜机的实例库,运用最相邻策略法进行镀膜机实例的检索,采用基于框架的方案变换方法对检索的最相似实例进行修正。结果 以Pro Engineer 5.0为开发平台,开发了基于实例推理的镀膜机快速设计系统,实现了资源的整合和重复利用。通过测试,该系统使设计效率提高了30%。结论 将基于实例推理的快速设计技术引入到镀膜机的设计中,能够提高产品的设计效率和缩短产品的开发周期,从而解决客户个性化需求与大批量生产之间的矛盾,提高企业的市场竞争力。
Objective To study rapid design method of coater in mass customization. Methods Case-based reasoning technology was applied in the coater design process. Case-based reasoning principles and key technologies, coater cases presentation and the method to retrieve and amend were studied. Coater cases libraries were built and applied by database cases representation. The nearest neighbor method was used for retrieval of coater cases, and the method of transformation programs based on the framework was used to amend the most similar case. Results Based on the Pro ENGINEER 5.0 platform, case-based reasoning coater rapid design system was developed and resources were integrated and reused. Test revealed that the design efficiency of coater was improved by 30%. Conclusion With case-based reasoning technology applied to the coater design, the efficiency of product design was improved, the cycle of product development was shortened and the market competitiveness of enterprise was enhanced.
关键词:大规模定制 基于实例推理 设计系统 镀膜机
mass customization ; case-based reasoning ; design system ; coater ;
本帖被以下淘专辑推荐:
发表于 2016-1-7 06:24:16 来自手机 | 显示全部楼层
欧耶,太精彩了
发表于 2016-1-7 17:17:11 | 显示全部楼层
垃圾,没一点实际应用
