查看: 5489|回复: 0
[技术] CdSiP2晶体中光散射颗粒的研究
发表于 2015-7-12 23:14:08 | 显示全部楼层 |阅读模式
CdSiP2晶体中光散射颗粒的研究
Investigations on Optical Scatter Particles during CdSiP2 Crystals Growth
下载全文
CdSiP2晶体中光散射颗粒的研究.pdf (1.06 MB, 下载次数: 0)
作  者:张国栋 李春龙 王善朋 张翔 张西霞 陶绪堂
ZHANG Guo-Dong, LI Chun-Long, WANG Shan-Peng, ZHANG Xiang, ZHANG Xi-Xia, TAO Xu-Tang  (State Key Laboratory of Crystal Materials, Institute of Crystal Materials, Shandong University, Jinan 250100, China)
机构地区:山东大学晶体材料国家重点实验室山东大学晶体材料研究所,济南250100
出  处:《无机材料学报》 EI CSCD 2014年第29卷第8期 855-858页,共4页
Journal of Inorganic Materials
基  金:国家自然科学基金(51272129;50721002;50990061;50802054); 国家重点基础研究发展计划项目(“973”)(2010CB 630702)
摘  要:采用单温区法合成了CdSiP2(CSP)多晶原料,然后采用垂直布里奇曼法生长了大尺寸的CSP单晶。采用扫描电子显微镜、EDS对晶体中光散射颗粒的尺寸、形貌和成分进行了观察和检测。测试结果表明,所生长的CSP晶体中的光散射颗粒呈近椭圆形,尺寸为2~8μm,主要成分为Si,含量占88%以上。对CSP多晶合成的反应机理研究表明,此第二相颗粒是由于合成时多晶料中残留有少量未反应的Si单质所致。通过合成工艺的改进,有效地减少了晶体中Si散射颗粒的残留,制备出了高透明性的CSP单晶体。
Polycrystalline charges of CdSiP2(CSP) were synthesized by direct reaction method using P, Si, and Cd elements as the initial materials. Single crystals with the dimension of 8 mm in diameter and 40 mm in length were successfully grown by vertical Bridgman method. The dimension and the composition of the optical scatter particles in the CSP crystals were identified by SEM measurement. The results show that most of optical scattering particles are round-shaped with dimension of 2–8 μm. The EDS measurement result shows that the atomic percent of Si in the optical scattering particles is over 88%. The synthesis mechanism of CSP by single temperature zone method was studied by powder XRD. The results show that there is some unreacted silicon left when synthsized process is carried out below 1150℃. By optimizing the synthesis parameters and the Si inclusions were successfully restrained and the high optical quality CSP single crystal was obtained.
关键词:磷硅镉 非线性光学晶体 晶体缺陷 垂直布里奇曼法
CdSiP2 ; nonlinear optical crystal ; crystal defect ; vertical Bridgman growth ;
本帖被以下淘专辑推荐:
