查看: 4694|回复: 0
[技术] Yb3+∶LiYF4激光晶体的生长与光谱性能
发表于 2015-7-12 23:16:37 | 显示全部楼层 |阅读模式
Bridgman growth and spectral properties of fluoride laser crystal Yb3+ ∶LiYF4
下载全文
Yb3+∶LiYF4激光晶体的生长与光谱性能.pdf (1.72 MB, 下载次数: 0)
作  者:方义权[1] 赵学洋[1] 胡旭波[1] 向军涛[1] 陈红兵[1] 苏良碧[2] 徐军[2]
FANG Yi-quan, ZHAO Xue-yang, HU Xu-bo, XIANG Jun-tao, CHEN Hong-bing, SU Liang-bi, XU Jun (1. State Key Laboratory Base of Novel Functional Material & its Preparation Science,  Institute of Materials Science & Engineering, Ningbo University, Ningbo 315211,China; 2. Shanghai Institute of Ceramics, Chinese Academy of Sciences, Shanghai 201800, China)
机构地区:[1]宁波大学材料科学与工程研究所,新型功能材料及其制备科学国家重点实验室培育基地,浙江宁波315211 [2]中国科学院上海硅酸盐研究所,上海201800
出  处:《功能材料》 EI CSCD 2014年第45卷第17期 17145-17148页,共4页
Journal of Functional Materials
基  金:国家重点基础研究发展计划(973计划)前期研究专项资助项目(2011CB612306); 国家自然科学基金资助项目(21171102); 宁波大学王宽诚幸福基金资助项目(20131106); 宁波市光电功能材料及器件创新团队资助项目(2009B21007); 浙江省压电频率电子元器件技术及应用创新团队资助项目(2009R50025)
摘  要:报道了氟化物激光晶体Yb3+∶LiYF4的单晶生长与光谱性能。按照n(LiF)∶n(YF3)∶n(YbF3)=51.5∶47.5∶1.0制备配合料,经干燥HF气氛下的固相烧结合成制备出无水Yb3+∶LiYF4多晶料;采用非真空密闭条件下的坩埚下降法成功生长出系列?12 mm尺寸的透明完整Yb3+∶LiYF4单晶。采用化学分析和光谱测量表征了所生长单晶的掺杂浓度和光谱性能,结果表明,Yb3+离子已成功掺杂进入基质晶体,其有效分凝系数估算为0.455;此单晶在较宽波长范围内具有良好光学透过性,在896 nm波长激发光作用下,该单晶具有930-1 030 nm波长范围的荧光发射,其荧光衰减寿命为1 888μs。
The Bridgman growth and spectral properties of fluoride laser crystal Yb3 + ∶LiYF4 are reported in this paper.According to the molar ratio of n (LiF)∶n (YF3 )∶n (YbF3 )=5 1.5∶47.5∶1.0,the anhydrous polycrystalline material for Yb3 + ∶ LiYF4 crystal growth was synthesized by means of the fluoridation process under dried HF atmosphere at elevated temperature.A series of Yb3 + ∶LiYF4 single crystals with 12 mm in diameter were grown successfully by means of vertical Bridgman method under the sealed non-vacuum atmosphere.The dopant concentration and spectral properties of as-grown crystals were characterized by means of chemical analysis and spectroscopic measurements respectively.It was confirmed that Yb3 + ions had been doped into LiYF4 host crystal with effective segregation coefficient estimated to be 0.455.The single crystals exhibit a high optical transmittance in a wide wavelength range from ultraviolet to infrared region.Under the photonic excitation at 896 nm,the single crystals possess a fluorescence emission at the wavelength ranges from 930 to 1 030 nm with decay life time of 1 888 μs.
关键词:氟化物激光晶体 Yb3+∶LiYF4 单晶生长 坩埚下降法 光谱性能
fluoride laser crystal ; Yb^3+ : LiYF4 ; crystal growth ; Bridgman method ; spectral property ;
本帖被以下淘专辑推荐:
