2004-10-16 01:41:00 | 显示全部楼层 | 阅读模式
<>各位大侠,怎么在CODEV中建立自己的玻璃库,</P>
<>我看了帮助文件,可还是不行啊!</P>
<>请指点一下。</P>
[此贴子已经被作者于2004-10-19 20:03:35编辑过]
如何在CODEV中建立自己的玻璃库?
如何在CODEV中建立自己的玻璃库?
12.4k查看14回复
2004-10-18 02:33:00
难道就没有好心人帮忙吗?
2004-10-24 21:30:00
可以参考CODEV自带的宏.plasticprv.SEQ
内容如下:
!**************************************************************************** ! Sequence: PLASTICPRV ! ! Purpose: Macro to enter Private Catalog Information for Plastics ! ! Syntax: in PLASTICPRV ! ! Author: D. Hasenauer Date: 11-26-97 ! ! History: 11-26-97 DH New for 8.21 ! 07-27-00 DH Added Visible Glass Code for plastics ! 06-06-01 DH Modified Zeonex Data based on Zeon Corporation Data ! 08-27-01 DH Modified Zeonex Data to include Near-IR measurments ! 03-07-02 DH Formerly PRVPL.SEQ, changed name to be less cryptic ! Added index data for 4 Zeonor materials from Zeon Chemicals ! 02-25-03 DH Added Topas data from Ticona US (http://www.ticona-us.com) ! Removed Hoescht-Celanese COC data (now represented by Ticona) ! 05-22-03 DH Correct typo in d, F, C glass code !*****************************************************************************
prv
!! Data from OSA, "Handbook of Optics, Vol II", p. 34.7, Table 2
pwl 1014.0 852.1 706.5 656.3 643.9 589.3 587.6 546.1 486.1 480.0 435.8 404.7 365.0 'PMMAO' 1.4831 1.4850 1.4878 1.4892 1.4896 1.4917 1.4918 1.4938 1.4978 1.4983 1.5026 1.5066 1.5136 'P-STYRO' 1.5726 1.5762 1.5820 1.5849 1.5858 1.5903 1.5905 1.5950 1.6041 1.6052 1.6154 1.6253 1.6431 'P-CARBO' 1.5672 1.5710 1.5768 1.5799 1.5807 1.5853 1.5855 1.5901 1.5994 1.6007 1.6115 1.6224 1.6432 'SANO' 1.5519 1.5551 1.5601 1.5627 1.5634 1.5673 1.5674 1.5713 1.5790 1.5800 1.5886 1.5971 1.6125
pwl 643.9 587.6 546.1 480.0 'PEIO' 1.651 1.660 1.668 1.687
pwl 656.3 587.6 486.1 'PCHMAO' 1.502 1.505 1.511
!! Data from Honeywell France, Laurents Dispersion Coefficents
'PMMAH' lau 2.185936 8.0000e-6 1.453150e-2 -5.6315e-4 9.49030e-5 -3.9023e-6 'LUSTREXH' lau 2.445984 2.2000e-5 2.729890e-2 3.0121e-4 8.88930e-5 -1.7571e-6 'LEXANH' lau 2.428386 -3.9000e-5 2.875740e-2 -1.9790e-4 1.48359e-4 -1.3865e-6 'LUSTRANH' lau 2.386870 -1.2310e-3 2.294680e-2 3.6981e-4 2.67580e-5 2.8480e-6 'POLEFINH' lau 2.212154 4.8611e-2 5.187444e-2 -8.0382e-3 6.10000e-4 -2.9862e-6
!! Cyclic-olefin CoPolymer (COC) - Topas Data provided by Ticona U.S., measured at 25 deg
pwl 1575 1325 1064.8 1013.98 852.11 706.52 656.27 643.85 632.8 587.56 546.07 486.13 479.99 435.84 404.66 365.01 337 290 240 "T5013" 1.5216 1.52234 1.52375 1.52417 1.52602 1.52895 1.53046 1.53089 1.53129 1.53322 1.53545 1.53984 1.54039 1.54515 1.54961 1.55724 1.56464 1.58316 1.61967 "T6013" 1.52199 1.52274 1.52416 1.52457 1.52643 1.52936 1.53088 1.53131 1.53172 1.53365 1.53589 1.54028 1.54084 1.54561 1.55007 1.55773 1.56511 1.58369 1.62027 "T6015" 1.52163 1.52237 1.52376 1.52417 1.52601 1.52891 1.53041 1.53084 1.53125 1.53317 1.5354 1.5398 1.54036 1.54515 1.54965 1.55741 1.56492 1.58397 1.6219 "T6017" 1.52181 1.52254 1.52393 1.52434 1.52618 1.52908 1.53058 1.53101 1.53141 1.53334 1.53558 1.53999 1.54055 1.54536 1.54989 1.55771 1.5653 1.58458 1.62313
!! OPTOREZ data from Hitachi data package, 25 deg C indices corrected to !! 20 deg, i.e., N(20) ~ N(25) - 5e-4
pwl 786.5 656.3 587.6 486.1 'OZ1000' 1.4932 1.4961 1.4990 1.5048 'OZ1100' 1.4960 1.4993 1.5020 1.5082 'OZ1310' 1.4992 1.5022 1.5054 1.5116 'OZ1330' 1.5026 1.5059 1.5091 1.5157
!! ZEONEX 786 - 435 nm Data from Zeon Chemicals Brochure - Cyclo-olefin Polymer Zeonex 01/2001 !! 1550 - 823 nm data provided by Zeon Chemical Company !! Data at 25 deg C
pwl 1550 1310 823 786.5 656.3 587.6 546.1 486.1 435.8 'Z-480R' 1.51233 1.51342 1.51789 1.51862 1.52196 1.52470 1.52692 1.53129 1.53649 'Z-E48R' 1.51749 1.51858 1.52310 1.52382 1.52713 1.52996 1.53226 1.53662 1.54205
!! ZEONOR 656 - 435 nm Data from Zeon Chemicals Excel file received 02/27/02 !! Average value of parallel and perpendicular measurements, temperature unknonw
pwl 656.28 643.847 587.56 546.07 486.13 479.992 435.84
'Z-1020R' 1.52772 1.52816 1.53054 1.53278 1.53721 1.53771 1.54247 'Z-1420R' 1.53131 1.53174 1.53411 1.53640 1.54079 1.54135 1.54612 'Z-1600R' 1.53231 1.53276 1.53514 1.53745 1.54186 1.54243 1.54725
pwl 656.28 587.56 546.07 486.13 435.84 'Z-1060R' 1.52749 1.53028 1.53253 1.53689 1.54219
end
!! Skipping older BF Goodrich Zeonex Data goto skip !! BF Goodrich Zeonex Cyclic Olefin Monomer, Grade 480, average of 15 deg 25 deg indices pwl 830 780 656.3 587.6 546.1 486.1 435.8 'Z480' 1.51899 1.519745 1.52298 1.52607 1.528275 1.532355 1.53794 ! Grade 480R, Cauchy dispersion fit from 280 nm to 1700 nm 'Z480R' cau 1.504 0.00557175 end lbl skip
wri "" wri " **************************************************************************************************" wri " Private Catalog refractive index information for several plastic" wri " materials has been entered. Optical characteristics for these" wri " materials may vary depending on purity, grade, and processing" wri " differences. This information is supplied for reference only." wri "" wri " VERIFY REFRACTIVE INDEX INFORMATION AVAILABILITY WITH YOUR VENDOR" wri " FOR ALL CRITICAL APPLICATIONS." wri "" wri " Key to Materials:" wri "" wri " Sources: [1] OSA Handbook of Optics, Vol. II, p. 34.7, Table 2" wri " ('room' temperature, actual measurement temperature unknown)" wri " [2] Measured Data by Honeywell France, fit to a Laurent's" wri " Dispersion Equation, dated January 1996 ('room' temperature," wri " actual measurement temperature unknown)" wri " [3] Data from Supplier, Ticona US , @25 deg C" wri " (http://www.ticona-us.com)" wri " [4] Data from Supplier, Hitachi Chemical Co., Ltd., 25 deg C indices" wri " corrected to 20 deg C (i.e., N[20] ~ N[25] - 5e-4)" wri " (http://www.hitachi-chem.co.jp/)" wri " [5] Data from Supplier, Zeon Chemicals at 25 deg C" wri " (http://www.zeonchemicals.com/)" wri " [6] Data from Supplier, Zeon Chemicals, temperature unknown, average" wri " value of two orthogonal measurements through the material" wri " (http://www.zeonchemicals.com/)" wri "" wri " Private Catalog Name Source Defined Wavelength Temperature d, F, C" wri " Name Region deg. C Glass Code" wri "" wri " 'P-CARBO' Polycarbonate [1] 1014 - 365 nm 'room' 585.300" wri " 'PCHMAO' Polycyclohexylmethacrylate [1] 656 - 486 nm 'room' 505.561" wri " 'PEIO' Polyetherimide [1] 644 - 480 nm 'room' 660.186" wri " 'PMMAO' Polymethylmethacrylate [1] 1014 - 365 nm 'room' 492.572" wri " 'P-STYRO' Polystyrene [1] 1014 - 365 nm 'room' 591.308" wri " 'SANO' Styrene Acrylonitrile [1] 1014 - 365 nm 'room' 567.348" wri "" wri " 'LEXANH' Polycarbonate [2] 1014 - 365 nm 'room' 585.303" wri " 'LUSTREXH' Polystyrene [2] 1014 - 365 nm 'room' 590.309" wri " 'LUSTRANH' Styrene Acrylonitrile [2] 1014 - 365 nm 'room' 567.348" wri " 'PMMAH' Polymethylmethacrylate [2] 1014 - 365 nm 'room' 492.575" wri " 'POLEFINH' Polyethlene (Polyolefin) [2] 830 - 435 nm 'room' 525.600" wri "" wri " 'T5013' TOPAS - Grade 5013 [3] 1575 - 240 nm 25 533.568" wri " 'T6013' TOPAS - Grade 6013 [3] 1575 - 240 nm 25 534.567" wri " 'T6015' TOPAS - Grade 6015 [3] 1575 - 240 nm 25 533.568" wri " 'T6017' TOPAS - Grade 6017 [3] 1575 - 240 nm 25 533.567" wri "" wri " 'OZ1000' OPTOREZ - Grade 1000 [4] 787 - 486 nm 20 499.574" wri " 'OZ1100' OPTOREZ - Grade 1100 [4] 787 - 486 nm 20 502.564" wri " 'OZ1310' OPTOREZ - Grade 1310 [4] 787 - 486 nm 20 505.538" wri " 'OZ1330' OPTOREZ - Grade 1330 [4] 787 - 486 nm 20 509.520" wri "" wri " 'Z-480R' ZEONEX - Grade 480R [5] 1550 - 436 nm 25 525.562" wri " 'Z-E48R' ZEONEX - Grade E48R [5] 1550 - 436 nm 25 530.558" wri " 'Z-1020R' ZEONOR - Grade 1020R [6] 656 - 436 nm 'room' 531.559" wri " 'Z-1060R' ZEONOR - Grade 1060R [6] 656 - 436 nm 'room' 530.564" wri " 'Z-1420R' ZEONOR - Grade 1420R [6] 656 - 436 nm 'room' 534.563" wri " 'Z-1600R' ZEONOR - Grade 1600R [6] 656 - 436 nm 'room' 535.560" wri " **************************************************************************************************" wri ""
2004-10-24 21:31:00
建立的方法,建议看一下帮助.多读几遍,你会有收获的.
2004-10-28 01:20:00
<P>谢谢先!</P>
2004-10-30 03:25:00
<P>我没有找到该文件,不过看过类似的seq文件,还是一头雾水。能否给个具体例子。</P><P>万分感谢!</P>
2004-11-8 17:30:00
以前曾见dfjss贴过一个如何建立塑料材料文件的帖子,不知道怎么找不到了,现在我正好需要用塑料材料!
2004-11-8 19:58:00
prv
end
2004-11-11 02:23:00
我用同样的方法建立过自己的玻璃,放入已经存在的seq文件中,但软件不能正确识别我的玻璃,会给出错误信息。是否还有其他步骤?
2004-11-12 16:22:00
请在私有玻璃名称前面加上引号, 如"PMMAO",'PMMAO', 两个引号必需一样.并且材料的名称最好大写.
2004-11-16 01:53:00
我在已经存在的玻璃库文件中,加入自己的玻璃。然后在数据编辑窗口中材料一栏中输入该玻璃名时给出以下信息: *** is not in a catalog - quotes needed for private cat. glass ***是我自己建立的玻璃名称。
不知如何解决?
2004-11-29 20:14:00
请在私有玻璃名称前面加上引号, 如"MMAO",'PMMAO', 两个引号必需一样.并且材料的名称最好大写
12下一页
