查看: 5249|回复: 0
[技术] Fe2+∶ZnSe 激光晶体光学吸收及激光输出性能
发表于 2015-7-12 23:19:19 | 显示全部楼层 |阅读模式
Optical absorption and laser output performance of Fe2 + ∶ZnSe laser crystal
下载全文
Fe2+∶ZnSe 激光晶体光学吸收及激光输出性能.pdf (200.69 KB, 下载次数: 0)
作  者:夏士兴[1,2] 张月娟[2] 李兴旺[2] 王永国[1,2] 莫小刚[2] 申英杰[3] 姚宝权[3]
XIA Shi-xing,ZHANG Yue-juan,LI Xing-wang,WANG Yong-guo,MO Xiao-gang,SHEN Ying-jie,YAO Bao-quan  ( 1. North China Research Institute of Electro-optics, Beijing, 100015, China ;  2. Beijing Opto-Electronics Technology Co. Ltd. , Beijing, 100015, China ; 3. National Key Laboratory of Tunable Laser Technology, Harbin Institute of Technology, Harbin 150001, China)
机构地区:[1]华北光电技术研究所 [2]北京雷生强式科技有限责任公司,北京100015 [3]哈尔滨工业大学可调谐激光技术国家重点实验室,哈尔滨150001
出  处:《激光与红外》 CSCD 2014年第44卷第9期 1000-1002页,共3页
Laser & Infrared
摘  要:采用热扩散掺杂技术制备了 Fe2+∶ZnSe 晶体,测试晶体样品中铁离子浓度达1.27×1018 cm -3。分析了 Fe2+∶ZnSe 晶体光谱的光学吸收特性,在室温条件下,采用2.90μm 激光器泵浦 Fe2+∶ZnSe 晶体,获得了中心波长4.45μm,平均功率67 mW 的中红外激光输出。
The Fe2 +∶ZnSe crystal has been prepared by thermal diffusion doping technique.The iron ions doping con-centration that was measured by Secondary Ion Mass Spectrometry (SIMS)in the crystal sample reaches 1.27 × 10 18 cm -3.The optical absorption spectrum of the Fe2 +∶ZnSe crystal was analyzed.The results show that a 2.90 μm laser is used to pump the Fe2 +∶ZnSe crystal at room temperature,67 mW average power of mid-infrared laser output at center wavelength 4.45 μm is obtained.
关键词:Fe2 + ZnSe 晶体 离子浓度 光学吸收 激光输出
Fe2 + ZnSe crystals ions concentration optical absorption laser output ;
本帖被以下淘专辑推荐:
