查看: 3415|回复: 0
[技术] 大屏幕投影显示光学系统的超薄化设计
发表于 2015-7-13 00:27:35 | 显示全部楼层 |阅读模式
大屏幕投影显示光学系统的超薄化设计
Design of ultra-thin optical systems in large screen projection display
下载全文
大屏幕投影显示光学系统的超薄化设计.pdf (362.33 KB, 下载次数: 5)
作  者:吕伟振[1,2] 刘伟奇[1] 魏忠伦[1] 康玉思[1] 田志辉[1] 孟祥翔[1,2]
L,Wei-zhen,LIU Wei-qi,WEI Zhong-lun,KANG Yu-si,TIAN Zhi-hui,MENG Xiang-xiang( 1.U; 2.Changchun Institute of Optics, Fine Mechanics and Physics, Chinese Academy of Sciences, Changchun 130033, China;University of Chinese Academy of Sciences, Beijing 100049, China;)
机构地区:[1]中国科学院长春光学精密机械物理研究所,吉林长春130033 [2]中国科学院大学,北京100049
出  处:《光学精密工程》 EI CSCD 2014年第22卷第8期 2020-2025页,共6页
Optics and Precision Engineering
基  金:国家863高技术研究发展计划资助项目(No.2009AA032701)
摘  要:针对大屏幕投影显示对成像物镜提出的超短焦、大视场角、超薄化、大相对孔径以及高清晰度等要求,设计了一种新型折反射式超薄投影成像系统.采用TI公司的0.65″数字微反射镜片(DMD)作为空间光调制器,利用非球面反射镜校正畸变并缩短投影距离,然后通过一个折叠反射镜对光路进一步转折来实现超薄化投影显示.系统由5片透射镜片和1片非球面反射镜组成,焦距为2.8 mm,F/#为3.5,最小视场角为55°,最大视场角为78.5°,在投影距离为120 mm时画面尺寸显示为65.2″.设计结果表明:在像面的Nyquist频率处,95%以上视场的MTF>0.6,最大畸变量为0.8TV%,一个像元尺寸内能量集中度在90%以上.为了进一步验证折反射式超薄投影镜头的性能,加工并组装了原理样机.实验结果表明其图像显示效果良好,能够满足超薄化、低成本、小型批量化生产等设计要求.
A novel ultra-thin refract-reflect projection display system was designed to meet the severe requirements of imaging lens in large screen projection display for ultra-short focal length,larger field of view,ultra-thin,larger relative aperture and higher resolution.A 0.65 inch (16.51 cm) Digital Micromirror Device (DMD) produced by TI Inc.was employed as the spatial light modulator and an aspheric mirror was used to correct distortion and shorten projection distance.Furthermore,a fold mirror was also taken to turn back the optical path to achieve ultra-thin projection display.The system is consisted of five lenses and an aspheric mirror,of which the focal length is 2.8 mm,the Fnumber is 3.5 and the minimum and the maximum field angles are 55° and 78.5°,respectively.When the projection distance is set to be 120 mm,the screen size can be 65.2 inch (165.6 cm).With the design,it shows that the Modulation Transfer Function(MTF) of over 95% field of view of the system is higher than 0.6 at the Nyquist frequency of the image plane.The maximum distortion is 0.8TV%,and 90% geometric encircled energy in the point target is focused in one pixel.To verify the performance of the ultra-thin refract-reflect projecting lens,a principle prototype was fabricated and assembled.The experimental results show that the system has excellent display performance,and meets the design requirements of ultra-thin,low cost and small-scale mass production.
关键词:光学设计 投影显示 大屏幕显示 数字微反射镜片 超薄投影显示系统 非球面反射镜
optical design ; projection display ; large screen display ; digital micromirror device ; ultrathin projection display system ; aspheric mirror ;
本帖被以下淘专辑推荐:
