查看: 4148|回复: 0
[资料] 高清激光显示中的色彩复现系统
发表于 2015-7-13 00:38:17 | 显示全部楼层 |阅读模式
高清激光显示中的色彩复现系统
Color-recurrent system in high-definition laser display
下载全文
高清激光显示中的色彩复现系统.pdf (1.2 MB, 下载次数: 1)
作  者:付瀚毅[1,2] 刘伟奇[1] 柳华[1] 冯睿[1] 康玉思[1] 陶淑苹[1]
FU Han-yi ,LIU Wei-qi ,LIU Hua ,FENG Rui ,KANG Yu-si ,TAO Shu-ping(1. Changchun Institute of Optics, Fine Mechanics and Physics,  Chinese Academy of Sciences, Changchun 130033, China;2. University of Chinese Academy of Sciences, Beijing 100049, China)
机构地区:[1]中国科学院长春光学精密机械物理研究所,吉林长春130033 [2]中国科学院大学,北京100049
出  处:《光学精密工程》 EI CSCD 2014年第22卷第7期 1774-1780页,共7页
Optics and Precision Engineering
基  金:国家863高技术研究发展计划资助项目(No.2007AA030111,No.2009AA032701)
摘  要:利用60吋全固态激光电视样机,建立了原有的电视色度信号向激光电视色度信号转换的模型。根据激光显示的特点,推导出以三色激光(红:660nm,绿:532nm,蓝:457nm)为三基色的激光电视颜色系统与荧光粉电视三基颜色系统的矩阵转换关系。利用解码模块、现场可编程门阵列(FPGA)色域转换模块和编码模块搭建了激光三基色系统和普通电视三基色系统的色域转换电路,分析了电路中各个模块的作用及整个电路的工作过程,实现了对高清视频信号的色域转换。对比了不同颜色在转换后的激光电视上与荧光粉电视上的显示效果,对11个特征颜色的测量显示,其色域转换误差小于9.8%。实验取得了很好的色域转换效果,成功地验证了高清激光电视的色彩复现能力。
On the basis of an 60 inch all solid laser television(TV)prototype,a chrominance signal conversion model from an original TV to a laser TV was established.By researching the characteristics of laser display,the conversion matrix between traditional phosphor TV color system and laser TV color system was derived by using a three color laser(red:660nm,green:532nm,blue:457nm)as primary-color.A gamut conversion circuit between the two color systems was given by utilizing a decode module,a Field Programming Gate Array(FPGA)controlling circuit and a coding module.The roles of these models and their working processing were analyzed,and the gamut conversion to the high-definition video signal was achieved.11feature colors displayed with the laser TV and the traditional phosphor TV respectively were measured and compared after conversion and the gamut conversion error is less than 9.8%.The experiment obtains an excellent result of gamut conversion and verifies the color-recurrent ability of high-definition laser TVs.
关键词:激光电视 激光显示 颜色系统 色域转换 现场可编程门阵列
laser television laser display color system gamut conversion Field Programming Gate Array(FPGA) ;
本帖被以下淘专辑推荐:
