查看: 4504|回复: 1
[技术] 大视场偏振CCD相机的偏振特性实验标定
发表于 2015-7-13 00:45:59 | 显示全部楼层 |阅读模式
大视场偏振CCD相机的偏振特性实验标定
Polarimetric Calibration of the Polarization CCD Camera with Large Viewing Field
下载全文
大视场偏振CCD相机的偏振特性实验标定.pdf (348.44 KB, 下载次数: 9)
作  者:陈立刚
CHEN Ligang  ( Opto-Electronic Information Engineering Research Center, Binzhou University, Binzhou 256600, Shandong Province, China )
机构地区:滨州学院光电信息工程研究中心,山东滨州256600
出  处:《光电工程》 CSCD 2015年第42卷第2期 15-20页,共6页
Opto-Electronic Engineering
基  金:国家自然科学基金项目(41201368);山东省高等学校科技计划项目(J14LJ02);滨州学院科研基金项目(2013Y09)
摘  要:大视场偏振CCD相机内部的多个光学表面会改变入射光的偏振状态,并且改变的程度与入射光的偏振态、视场角和方位角等有关,影响了仪器偏振测量精度,从而制约了偏振成像遥感数据的定量化应用水平。为解决这一问题,从考虑偏振效应的大视场偏振相机响应输出模型出发,研究模型参数的标定方法,通过设计试验获取了模型参数标定数据。将经过标定的大视场偏振 CCD 相机测试值和可调偏振度光源预设偏振度值进行对比,结果显示偏振相机在0°、15°、25°视场角下的偏振度测量平均误差不大于1.18%,远小于光学镜头自身的起偏度。消除偏振遥感仪器自身的偏振敏感性影响,为将来我国自主星载偏振遥感图像的定量化应用奠定基础。
The polarization state of the object is altered due to the surfaces of the optical lens in the polarization CCD camera with large viewing field, and the variation relate to the field of view, azimuth angle and polarization states of the observed beams. The polarimetric accuracies limit the application of polarization remote sensing due to the polarization phenomenon of the instrument. To overcome the problems, calibration method of the model parameters and retrieval of the polarization information is introduced based on the polarimetric calibration model. In order to verify the calibration method feasibility, the Degree of Linear Polarization (DOLP) comparison tests of the calibrated polarization CCD camera with large viewing field compared with the high-precision variable polarization light source have been carried out. Experimental results show that the DOLP accuracy of the calibrated polarization CCD camera is better than 1.18% at the 0°, 15° and 25° field of view. The method of polarimetric calibration would get rid of the influence of polarization phenomena of the polarization CCD camera, and contribute to fundamental basis for the quantitative application of polarization remote sensing information for the Chinese polarized satellite sensor.
关键词:偏振遥感 偏振相机 偏振定标
polarization remote sensing ;polarization camera ;polarimetric calibration ;
本帖被以下淘专辑推荐:
发表于 2015-7-13 01:32:55 | 显示全部楼层
xie xie
